Understanding Spin Relaxation: A Brief Exploration
  • Context: Graduate
  • Thread starter Thread starter JanSpintronics
    Spin
Spin relaxation refers to the decay of net magnetization in a spin-polarized current, where individual spins become misaligned due to varying external fields and interactions with their environment. In Nuclear Magnetic Resonance (NMR), spin-lattice and spin-spin relaxation rates illustrate how spins lose their alignment when not strongly coupled. The phenomenon occurs because, once an external magnetic field is removed, the spins do not remain aligned due to their individual environments. It is important to note that magnetic fields do not influence nuclear decay processes.
  • Understanding of spin polarization and magnetization
  • Familiarity with Nuclear Magnetic Resonance (NMR) concepts
  • Knowledge of angular momentum and torque in classical physics
  • Basic principles of magnetic fields and their effects on particles
  • Research the principles of Nuclear Magnetic Resonance (NMR) and its applications
  • Explore the effects of magnetic fields on spin dynamics in quantum mechanics
  • Study the differences between spin-lattice and spin-spin relaxation
  • Investigate the role of environmental factors in spin relaxation processes
Physicists, materials scientists, and researchers in quantum mechanics or NMR who seek to deepen their understanding of spin dynamics and relaxation phenomena.
JanSpintronics
Hello,
Im not sure if get the meaning of spin relaxation. In the case, if you have a spin polarized current, what happens there if you talk about spin relaxation? Is it just the phenomena that after some time the spins will pointing in all direction?
If that is right why that happens?
JanSpintronics said:
Hello,
It's the decay of a net magnetization.
Why? Because of many things, such as the individual spins are in different external or inhomogeneous field. This is why, for example, in NMR, there is a spin-lattice relaxation and spin-spin relaxation rates. Each of the individual spins are in different environment, and they are not strongly coupled to one another.
Think of it. If they all started out as not being aligned, and then they were aligned by some external field, and then the field is switched off, if they are not strongly coupled to one another, why should they continue to be aligned?
Zz.
Go back to classical physics. There is a spinning body, a torque applied at an angle to the axis of the spin, the net result is a precession of the axis of the spinning body.
Back to the NMR, the spin magnetic moment is a result of a "rotation", i.e. angular momentum of some kind. Apply a uniform magnetic field, this produces a torque that is a vector product of the magnetic moment (aligned with the direction of the spin) and the magnetic field. This torque will result in a precession of the axis of the spin. In the absence of any dissipation, the spin will go forever and the system would never achieve the lowest energy state - the spin aligned with the magnetic field.
Spin relaxation is just a measure of interaction between the spinning electron and it's environment that can dissipate the precession and result in the alignment of the spin with the magnetic field.
Does this mean you could actually change a substance with a magnetic field, like possibly get rid of nuclear waste with the right magnetic field?
No, because the nature of nuclear decay is not affected by magnetic field.
You need to find properties that ARE affected by the magnetic field. Otherwise, you are making connection between things that have no connection, such as in a superstition.
This is also getting to be off-topic. We are addressing specific issue in the OP's question.
Zz.
Thanks for your opinion!
