What is the acceleration normal to PC in polar coordinates?
34 replies · 5K views · last reply
Jahnavi
Physics problem diagram: circle with centre O, fixed point C on the circumference, particle P on the circle, force F directed from P toward C, angle θ at C between CP and CO; text asks for the ratio of d²θ/dt² to (dθ/dt)² with options tanθ, 2tanθ, cotθ, 2cotθ.
Since the force is always directed towards C , angular momentum about C should be conserved . But that doesn't seem to help as we need the relation at any general angle .
How should I proceed ?
  • Physics problem diagram: circle with centre O, fixed point C on the circumference, particle P on the circle, force F directed from P toward C, angle θ at C between CP and CO; text asks for the ratio of d²θ/dt² to (dθ/dt)² with options tanθ, 2tanθ, cotθ, 2cotθ.
Point P moves along a circle centered at point O. Knowing that the force exerted on it points towards C, what are the radial and tangential accelerations in terms of theta?
In question already mentioned that point is moving only under the force acting towards C then from where tangential acceleration comes.
If it were moving only under the force acting towards C, it wouldn't be moving in a circle as shown. It has both radial and tangential accelerations.
Read question
Read question
I did. It's the 'net force' that acts towards C. It has both radial and tangential components such that the particle moves on a circle as shown.
You can broke the component of F along x and y direction.point is moving in circle but force not directed towards centre and as point move distance between point c and point p changes.i think it moves under some kind of restoring force
Fortunately, we don't have to analyse the nature of force in the question. You can arrive at the answer with elementary trig and vector algebra.
Thanks !
Is this type of circular motion actually possible with the single force as shown in the picture ?
Is this some sort of planetary motion around the sun with perigee coinciding the focus ?
Yes, and the condition under which it is possible is what the question is asking for.
I think it's the other way round :smile:
Possibly, but did you get the answer? If you did, I can stop posting here since it's beyond my expertise to discuss the nature of this force (and the planetary motion you mentioned):-p.
I get option a) . Do you get the same ?
No.
Jahnavi said:
Sorry . I am actually getting option b) .
@ehild , please reply to post#9 .
Unless I made some stupid mistake, it's d).
But I suppose now you know how to do it.
Let me check my work .
Edit : I am still getting option b) .
You calculated (d2θ/dt2)/ (dθ/dt)2 right? It comes out to be 2cotθ.
I think you calculated the reciprocal.
I also get (B). Consider θ=0. Would it not make sense that ##\ddot\theta=0## but ##\dot\theta<0##?
You're right!
In my working, I had drawn the 2 radii perpendicular to each other in the diagram, so my θ was 45 degrees there. And using the alternate angles, I concluded that tanθ=Ft/Fr. Actually, tanθ=cotθ at θ=45°, so my assumption worked for θ=45° but it's actually cotθ=Ft/Fr.
Tricked by my own drawing!
My apologies!
Jahnavi said:
Thanks !
Yes.
I don't think so. The force points to C, but its magnitude changes along the circle. It is zero at C and highest at the opposite point.
Diagram of a circle with centre O, a point C on its left edge and a point P on its upper right edge. A red arrow labelled F points from P toward the interior, with a line from C to P, and the angles theta at C and phi at O marked.
I also got B.
  • Diagram of a circle with centre O, a point C on its left edge and a point P on its upper right edge. A red arrow labelled F points from P toward the interior, with a line from C to P, and the angles theta at C and phi at O marked.
See Post #21
Please explain how do we infer this from the question .
If we look in polar form then r and Θ both varies with respect to time.we can find expression for acceleration using r and Θ
Yes. The necessary and sufficient condition that the motion is controlled by such a force is one of the equations needed to arrive at the desired equation.
No. The trajectory would need to be an ellipse with the source of the force at one focus. Yes, a circle is a special case of an ellipse but its focus would be at the centre, not on the circumference.
Do you think If I write the two eq of motions then I should end up with a circular path ?
But since type of force is unknown how to do that ?
I am curious as to how this force makes the particle move in a circle .
You do not know the magnitude of the force towards the origin, but you do know the magnitude in another direction.
Which direction ?
