What Is the Angle of Reflection in a Plane Mirror?
The discussion revolves around the concept of reflection in plane mirrors, specifically focusing on the relationship between the angle of incidence and the angle of reflection. Participants explore various scenarios involving light rays and their angles relative to the mirror.
  • Participants attempt to understand whether the angle of reflection always equals the angle of incidence, with specific examples provided. Questions arise about how angles are defined and calculated in relation to the mirror.
The discussion is active, with participants questioning and clarifying definitions related to angles of incidence and reflection. Some guidance has been offered regarding the geometric definitions of these angles, but no consensus has been reached on the specific calculations for the scenarios presented.
Participants express confusion regarding the definitions and relationships between angles in the context of light reflection. There is an emphasis on understanding the geometric aspects of the problem, and some participants are working through their assumptions about the angles involved.
Coco Hwang
1) If the angle of incidence of a ray of light to mirror is 50 degrees, what is the angle of reflection from the mirror?
2) If the angle of incidence of a ray of light to a mirror is 20 degrees, what angle does the light ray make with the mirror when it reflects?
3) If a ray of light makes an angle of 58 degrees with a mirror, what is the angle between the incident ray and the reflected ray?
The attempt - I'm having a hard time understanding the concept of mirrors, does the angle of reflection always equal to the angle of incidence?
Thank you!
Yes.
haruspex said:
Yes.
thank you!
would this also apply for light rays?
Coco Hwang said:
thank you!
Also? What were we discussing if not light rays?
Sorry, I was not aware that angle of reflection and light rays were the same thing.. :sorry:
They're not the same thing. Light rays are reflected in mirrors. The angle of reflection is an attribute of that reflection.
Although "reflection" generally refers to light, we can use the term in other contexts, figuratively.
But in the context of the present question, we are definitely discussing reflection of light rays.
Oh I see, thank you for your detailed response! So in this situation, would the answers for both questions #1 and #2 be the same as their angle of incidence?
For #1, yes, but for #2 you need to think carefully about how the following are defined:
  • Angle of incidence
  • Angle of reflection
  • Angle between the light ray and the mirror
ok so for #2, would I subtract 20 degrees from 90 degrees? ( 70 degrees ) Or do I just multiply 20 two times ( 40 degrees )
One of those is correct. Which one and why?
Ummm, is it subtracting 20 from 90? Because the angle of incidence is 90 so I subtract the angle made from the reflection from it?
Yes, but why? How is the angle of reflection defined, geometrically? How is that different from the angle the reflection makes to the mirror?
  • · Replies 16 ·
