What is the approach to calculating line integrals in a vector field?
The discussion revolves around calculating line integrals in a vector field, specifically focusing on the vector field F(x,y,z) = (y-2x)ux + (y^2-x^2)uy and the curve defined by the parabola y=3x^2. Participants are attempting to understand how to express points on the curve in terms of the vector field and how to set up the line integral correctly.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss parameterizing the curve and expressing the vector field in terms of the parameter. There are attempts to substitute y=3x^2 into the vector field and to express the line integral in terms of the parameter t. Questions arise about how to correctly set up the integral and the limits of integration.
The discussion is ongoing, with participants sharing their attempts to parameterize the curve and calculate the integral. Some guidance has been offered regarding the parameterization of the curve and the expression of the vector field in terms of the parameter. However, there is still uncertainty and confusion about the correct setup and calculations.
Participants are working under constraints typical of homework assignments, including the requirement to arrive at a specific answer. There is mention of potential errors in calculations and the need to clarify the parameterization and limits of integration.
pakkanen
First I want to greet everyone because I am new here.
I have attended to applied electromagnetic course which seems to be pretty hard to understand and issues came up at very first time after I went at calculations.
I try to explain this as good as possible.
1. Vectorfield F(x,y,z) = (y-2x)ux + (y2-x2)ux. Calculate the fields line integral among the parabola y=3x2, from origin to poin r (r=ux-3uy).
Does it mean that every point of the slope y=3x2 can be expressed in terms of vector field F?
I have tried the following
I put F=r to express the amound of x and y is needed in vector field F to reach point r. It gives me the following:
y-2x = 1
y2-x2 = 3
Does this make sense? I know that vector field´s line integral is int(F-dot-d)
Next I have tried to make this happen and had
int(Fx,y,z-dot-dx,y)
int[-ux+uy(2y-2x)].
How I implement the y=3x2 in this integral? Shouldn´t the integral be
int(3x2) from point 0 to r?
I also have tried to put the function y=3x2 to F(x,y,z) and tried int[(3x2ux-2xux+9x4uy-x2uy)*(dux+duy)
After this I had 2x2+9x4-2x and tried to put value for X which i got when I did F = r but it doesn´t seem to work.
Can anyone give me a clue how should I THINK or understant this? How do I make the calculation?
The answe should be 15/2
ok so we want to calculate
[tex]\int_C \vec{F} . d\vec{r}[/tex]
Where C is curve y=3x2 from (0,0) to i+3j (i is the same as ux and j is the same as uy). So it is basically from (0,0) to (1,3) .
I think it should be i+3j or (1,3) as (1,-3) does not lie on the curve. So you can easily parameterize the curve by letting x= some function of t.
so now find [itex]\vec{r}[/itex] for the curve which is in the form [itex]\vec{r} = x(t)\hat{i} + y(t) \hat{j}[/itex].
So what is your range of values for t on the vector r?
When you have this. You can easily parameterize F (make x in terms of t and y in terms of t) and you can find dr
Ok, I have tried this but something is still going wrong.
I replace the y = 3x^2 to in F(x,y,z) and I get F(x,y,z) = (2x2-2x)ux + (9x4-x2)uy
So I know the y in terms of x in the vector field.
I tried to somehow force r in terms of x and y and got r = 1ux and 720uy but I think this is not going to work..
What it means that I have to take [itex]\vec{r} = x(t)\hat{i} + y(t) \hat{j}[/itex] in terms of t?
How I express r in values of x and y? Do I need to replace ux and uy or how I erase them
You can always parameterize an equation y = f(x) by letting x = t, y = f(t). In your case you would get:
r(t) = t i + 3t2j
Well you need to do what LCKurtz suggested. I don't think it matters whether you use ux for i or uy for j.
When you find [itex]\vec{r}[/itex]. You need to also get [itex]F(\vec{r(t)})}[/itex]
Ok, thank you by far. this is makes sense now but I still can´t get the right answer.
I got got that the following,
r = ti + 9t2j => dr = d(ti) + d(9t2j)
And the F would be F = (3t2-2t)i + (9t4-t2)j
Can I now take dr = (i + 9tj)dt? Ok, I have done this and int(F.dt):
I had int(3t2-2t+81t5-9t3) with only t:s
How do I get t:s? i tried to put F(t) = r(t) and got 27t4-2t-10 = 0. i mean I put 3t2-2t = 1 and 9t4-t2 = 3 and got very nonsense with t = about -/+ 0,809... I tried to integrate from 0 to t and got some ********.
Your r should be ti + 3t2j. When t = 0 the point is at (0,0) and when t = 1 the point is at (1,3) on your parabola. So the t variable in the integral should go from 0 to 1.
hmmm. of course. int(3t2-2t+81t5-9t3) that is
/(t3 - t2 + 13,5t6 - 2,25t4) right?
Now from 0 to 1 gives me 11,25 and the answer should be 7,5. Somewhere is still error but I can´t find it.
