What is the average force exerted on a rocket during acceleration?
7 replies · 3K views
brake4country
A rocket with a mass of 7.2 x 10^4 kg starts from rest in outer space and fires its thrusters until it is moving with a velocity of 100 m/s. What was the average force on the rocket due to the thrusters?
1/2 mv^2 = Fxd
I attempted this problem using conservation. However, I keep getting an answer with "d" yet I am unable to solve for d. Can anyone point me in the right direction?
I suspect the problem creator wants the average force per time unit. Do you know of some physical observable which depends on force and time? (And perhaps one that is also conserved in absence of forces)
Edit: upon rereadin, the time is not specified either. Is the problem formulation exactly as stated?
That would be acceleration?
Acceleration is only dependent on force and mass. As stated, the problem is only solvable if we assume a constant force, which seems a bit confusing since the problem mentions "average force". Had you been given the time it took to accelerate the rocket, things would have been different.
No, the problem does not give a time. However, if we use impulse = mv = Ft, then yes, if given the time then Force could be solved. It appears that this problem does not have enough information to solve. How do we know that there is not enough information to solve this problem?
I see. Also, I understand now that if a problem omits both time and distance there won't be enough info. to solve. This is true for the kinematic equations. Thank you!
