What is the best topology for adding surge protection to Ethernet PHY?
  • Thread starter Thread starter johnkelton
    Magnetics Modules
The discussion centers on the optimal placement of a surge protector in relation to an Ethernet PHY and a magnetic module. Two topologies are considered: placing the surge protector before or after the magnetic module. The user highlights that placing the surge protector after the magnetic module may require higher specifications, affecting cost and size, which is critical due to limited PCB space. Another participant suggests that primary transient protection should be at the RJ45 connector to shunt most transient energy to ground, with secondary protection after the transformer. The conversation emphasizes the importance of balancing protection effectiveness and component size in design.
johnkelton
Hi, Guys I have a B78476A8135A003 Magnetic Module from EPCOS and I want to add a surge protector either on the TJ45 connector side or the Ethernet PHY side. I can't decide which way is more beneficial. Here is the topology:
Ethernet PHY : B78476A8135A003 : Surge Protector (SLVU2.8-4) : RJ45
OR
Ethernet PHY : Surge Protector (SLVU2.8-4) : B78476A8135A003 : RJ45
Also, the datasheet of B78476A8135A003 doesn't talk about its surge or ESD specs. How can I determine those specs?
Thanks
OR
Thanks
Welcome to the PF.
Does the Surge Protector not come with some application note?
Hi, Thanks for your reply. Yes you are right it did come with the application note. However, the application note is actually the options mentioned above. It does not go into the benefits of either topology over another. I am mainly interested because let's suppose a surge happens, then Magnetic module (1:1 ratio transformer for Tx and Rx) in theory should help diminish the effects of the surge because its composed of couple of inductors. If I add a surge protector component the following way:
then the surge protector components needs to have higher spec which means >$ and >size.
However if the other topology is used then I can lower the spec of the surge protector which will allow me to use small package size (very important for my pcb as I have very little space).
Your thoughts!
Your thoughts!
Can you give a link to the application note?
I don't work with Ethernet PHYs much, but I do work with other types of communication networks. I usually put the primary transient protection at the network input (your RJ45) before the transformer. Then I put secondary transient protection after the transformer before the transceiver silicon (usually just clamp diodes to the rails). The primary protection shunts most of the transient energy to Earth ground, so only a little is left to couple through the transformer.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
