What is the change in internal energy of the water
The discussion focuses on solving two physics problems related to changes in internal energy and temperature. For the first problem, a 2kg chunk of ice at -10°C is added to 5kg of water at 45°C, with the final temperature calculated incorrectly initially, but later clarified to require warming the melted ice to the final temperature. The second problem involves calculating the change in internal energy when 0.2kg of water at 100°C is converted to steam at the same temperature, with the correct approach involving latent heat and volume changes. The final calculations for both problems were successfully resolved, leading to the correct answers. The thread concludes with the problems being solved and the discussion closed.
Kristmas
Hi there, I have some serious problems with a couple of questions. Need help for exam revision.
1.1 Homework Statement
A 2kg chunck of ice at -10Celsius is added to 5kg of water at 45Celsius. What is the final temperature of the system?
1.2 Relevant equations
specific heat capacity of ice - 2100 Jkg-1K-1
specific heat capacity of water - 4190 Jkg-1K-1
latent heat of fusion for ice - 334 000 Jkg-11.3 The attempt at a solution
Using formula E=mC(change in)T
E1 - 2 x 2100 x 10 = 42000J
E2 - 2 x 334 000 = 668 000J
E3 - 668 000 + 42 000 = 710 000J
E4 - 710 000=5 x 4190 x (change in)T T=33.89Celsius, so final temperature is 45-33.89=11.11, but the correct answer has to be 7.9Celsius.
2.1 Homework Statement
A cylinder with a piston contains 0.2 kg of water at 100 Celsius. What is the change in internal energy of the water when it is converted to steam at 100Celsius at a constant pressure of 105 Nm-2?
2.2 Relevant equations
latent heat of vaporisation of water - 2.26 x 106 Jkg-1
density of water - 1000 kgm-3
density of steam - 0.6 kgm-3
2.3 The attempt at a solution
Using (change in) U=(change in)Q - P x (change in)V
U=internal energy, Q=heat, P=pressure, V=volume
Change in heat is 2.26 x 106 x 0.2 = 452 000 J
Can't manage more :(.
Supposed answer is 418.7 kJ.
"E4 - 710 000=5 x 4190 x (change in)T"
This is not correct.
You have to warm up to the 2kg 0 oC melted ice to the final temperature.
Sorry, I can't see it still. I know it has taken 710 000Joules of energy to get the ice to 0 Celisu and melt completely to water. So I thought i simply take that energy away from the water at 45 Celsius. Thus using Energy=mass*specific heat capacity of water* change in temperature to get the change in temperature from 45.
It is true that you need that 710000 J to warm up and melt the ice to oC water. That energy is taken away from the 45 oC water, but you still have 2 kg 0 oC water to be warm up to the final temperature.
ehild
Thank you Ehil, I got the answer to question 1 now.
Worked out solution to question 2 as well.
Change in heat is 0.2 x 2.26 x 106 Jkg-1=452 000 Joules
Pressure is already given at 100 000 Pa
Original volume is mass/density, so 0.2/1000=0.0002m3.
Mass stays the same, so 0.2kg of steam occupies: 0.2/0.6=0.333333 m3 of space. Change in volume is the volume of steam - volume of water, 0.333333-0.0002=0.333133m3.
So using the overall equation: 452 0000J - 100 000Pa x 0.333133m3=418 686.7 J.
Can close the thread.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
