What is the charge of the 10 billion electrons?
  • Thread starter Thread starter Marcin H
    Charge Electrons
The charge of 10 billion electrons can be calculated using the formula Q=Ne, resulting in a charge of 1.6E-9 C. The discussion also addresses how to determine the energy stored in a 12V, 35Ah battery, suggesting the use of the power equation P=IV to find energy in Watt-hours, which can then be converted to Joules. To find how long the battery will last when supplying 0.5A, the relationship between ampere-hours and current is utilized, leading to the conclusion that the battery will last approximately 70 hours. The conversation emphasizes the importance of understanding the relationships between current, time, and battery capacity. Overall, the participants clarify the calculations and concepts related to electric charge, energy, and battery life.
Marcin H
:[/B]
I have a battery and lightbulb circuit (in series). 12V battery rated at 35Ah.
Ten billion electrons pass a planar cross section of the wire. What is the charge of the 10 billion electrons?
Q=Ne
I=dq/dt
1A=1C/s
Is this as simple as using Q=Ne or not? I may be overthinking this, but this doesn't seem right.
Q = Ne
Q=(#electrons)(electron charge)
Q= (1E10)(1.6E-19 C)
Q = 1.6 E -9 C
Not an advanced physics problem, so moved to Intro Physics
Assuming you have the question right, that's all there is to it. (Get the sign right.)
Likes Marcin H
Ok. Follow up question. How many Joules of energy does the battery I mention store? I would use .5CV^2 or .5QV, but this is what I learned in E&M physics, so I think there is another way. This is EGR 110 intro to electrical and computer engineering, so there are no pre-recs. Is there a way to do this using unit conversions?
Marcin H said:
:[/B]
Q=Ne
I=dq/dt
1A=1C/s
Q = Ne
Q= (1E10)(1.6E-19)
Q = 1.6 E -9
Always state your units; chances are the question would be marked wrong without them. Otherwise, it looks OK.
Hint: If the battery delivered a current I, what power would it be delivering?
Yeah I was thinking about using P=IV, but I'm not sure we can. Can we still use that if we are given current in Amp hours?
Using P = VI is the first step. Now how do you go from power to energy? (Don't plug in numbers yet, just play with the equations symbolically.)
Oh I see. P=IV will give you units of WattHours and then you just do unit conversions and get it to Joules. Got it! Thanks!
Power will be in units of Watts; if you multiply by the time, then you'll have energy.
Likes Marcin H
Yeah, that's what I did. P= (12V)(35Ah) =420WattHours*(3600)
Good.
Doc Al said:
Good.
Ran into another problem. Assume the battery is supplying .5A of current to a light bulb. How long will the battery last? (Battery is 12V rated at 35Ah) I am supposed to use the 35Ah to find the time or do I have to somehow use the .5A. I don' t think there is a way to find how long it will last with just Amps. You need Amp hours to do this right?
You need to use both Amp-Hours and Amps to solve for the time.
Ok so, I used P=IV to find that the battery supplies 6W. I can do the same thing to find that it provides 420Wh. So can I just use unit conversions to find the hours? 6W/420Wh. Watts cancel and you are left with 1/70h. So 70 hours? Is this correct?
Sure.
All you have to do is realize that the ampere-hours are given so: 35 A-hr = I*T = .5A*T. Solve for T and get 70 hours.
Doc Al said:
Sure.
Can you explain that a bit more? Where did you get the "35 A-hr = I*T = .5A*T." part from
The battery capacity, expressed in terms of Amp-Hours, equals Current*Time. Draw a lower current and the battery can run for a longer time.
35 A-hr = (.5 A)*(70 hr) = (1 A)*(35 hr) = ... etc.
Ok, that makes sense. More sense than what I did. Is the way I did it a bad way to go about this? I don't know if I would have noticed to use that equation BC=AT on a test or quiz. I was just looking at units and trying to get hours through unit conversion.
No, just a bit more work than needed. Don't think of it as "unit conversion" though.
