What is the Charge on a Suspended Oil Drop in Millikan's Experiment?
  • Thread starter Thread starter washablemarker
    Charge Electron
The discussion centers on Robert Millikan's experiment to determine the charge of an electron using suspended oil drops. The key parameters include a potential difference creating an electric field of 10,000 N/C and an oil drop mass of 3.27 x 10^-16 kg. The charge on the drop is calculated using the equation qE = mg, leading to a charge magnitude of approximately 3.2 x 10^-19 C. Participants emphasize understanding the balance of electric force and gravitational force acting on the oil drop.
  • Understanding of electric fields and forces
  • Familiarity with Newton's laws of motion
  • Knowledge of basic electromagnetism concepts
  • Ability to manipulate equations involving mass, gravity, and electric charge
  • Study the derivation of the equation qE = mg in the context of electric forces
  • Learn about the principles of Millikan's oil drop experiment in detail
  • Explore the concept of electric fields and their applications in physics
  • Investigate the significance of the electron charge measurement in modern physics
Students in physics, educators teaching electromagnetism, and anyone interested in experimental methods for measuring fundamental physical constants.
washablemarker
Robert Millikan received a Nobel Prize for determining the charge on the electron. To do this he set up a potential difference between two horizontal parallel metal plates. He then sprayed a drops of oil between the plates and adjusted the potential difference until drops of a certain size remained suspended at rest between the plates. Suppose that when the potential difference between the plates is adjusted until the electric field is 10,000 N/C downward, a certain drop with a mass of 3.27 x 10^-16 kg remains suspended. what is the magnitude of the charge on this drop?
umm... i suppose E = Kc x (q/r^2) and f = Kc x (q1)(q2)/r^2 would apply. I'm not sure if i need anything else though.
i have got the right answer i think, but i have no idea how what is going on.
(3.27 x 10^-16)(9.8) = 3.2046 x 10^-15 = qE
E = 3.2 x 10^-19
i understand that here, mass is being multiplied by free fall acceleration, and then set equal to charge x electric field, but i don't know where this came from. does it have anything to do with the unit of electric force being Newtons, or kg x m/s^2. some explanation would be greatly appreciated.
Draw a free body diagram of the oil drop and work out the conditions for it to remain suspended.
yeah thanks. i figured it out minutes after. it's basically just electric field against gravity. thank you.
  • · Replies 52 ·
  • · Replies 26 ·
