What is the charge on the capacitor?
  • Thread starter Thread starter frederickcan
    Capacitor Charge
The discussion focuses on calculating the charge on a capacitor in a circuit where the switch has been closed for an extended period. The relevant equations include Ohm's Law (E - iR1 - iR2 = 0) and the capacitor discharge formula (Q = Qe^(-t/RC)). Participants emphasize the importance of combining resistors in series and suggest using Thevenin's theorem to simplify the circuit analysis. The discussion also highlights the need for a clear circuit diagram to facilitate problem-solving.
  • Understanding of Ohm's Law and circuit analysis
  • Familiarity with capacitor discharge equations
  • Knowledge of Thevenin's theorem
  • Basic circuit component values (resistors, voltage sources, capacitors)
  • Study Thevenin's theorem for circuit simplification
  • Learn about capacitor discharge and time constant calculations
  • Explore series and parallel resistor combinations
  • Review practical examples of capacitor charging and discharging in circuits
Students studying electrical engineering, physics enthusiasts, and anyone looking to deepen their understanding of capacitor behavior in circuits.
frederickcan
https://www.physicsforums.com/attachment.php?attachmentid=20071&stc=1&d=1250025514
The switch in the figure has been closed for a very long time.
(a) What is the charge on the capacitor?
(b) The switch is opened at t = 0 s. At what time has the charge on the capacitor decreased to 10% of its initial value?
E-iR1-iR2=0
emf (delta)Vi=0
Q=Qe^-t/RC (possibly)
So, I know that the circuit is initially closed, and I don't need current to solve. Also that I probably need to combine resistors because they are in series. Yet, I'm a little confused as how to set up the problem.
Any type of help or insight would be deeply appreciated.
You'll have to at least describe the circuit in words, if you can't post a graphic of it.
If we could see the picture it might help. If you can not load describe the circuit and value of the components. This would help a lot.
frederickcan said:
Does this link work?
The link does not work.
It looks something like this:____WWW______________
I...60 OHM...I...I
I......I...…
_ 100V....W...W
-....40 OHM W...W 10 OHM
I......I...…
I......I...… I_
I......I...… 2 micro F
I......I...…
I________________I_________I
Your picture is still not clear, I couldn't find where is the switch but general suggestions:
1) Convert your circuit to thevenian with capacitor at output (with one voltage source and one thevenian resistor)
2) 1/RC it T(time constant)
3) Use x(inf) - [x(inf) - x(0)] exp (-t/T) formula for finding voltage across capacitor as a function of t.
4) For steady state (when long time), make capacitor open and solve the circuit
