What is the Coefficient of Kinetic Friction on an Inclined Plane?
The discussion revolves around determining the coefficient of kinetic friction for a block projected up an inclined plane, which returns to its initial position with reduced speed. The problem involves concepts from mechanics, specifically energy conservation and friction on inclined planes.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss setting up energy equations, considering the work done by friction, and the relationship between kinetic and potential energy. There are inquiries about the normal force and frictional force in terms of the incline angle and coefficient of friction. Some participants express uncertainty about how to incorporate friction into their calculations.
The discussion is active, with various participants offering guidance on setting up equations and clarifying concepts like the work-energy theorem. There is a focus on understanding the relationship between the forces involved and the energy changes throughout the block's motion. Multiple interpretations of the problem are being explored, particularly regarding the role of friction.
Participants note the presence of multiple unknowns in the problem, such as the height attained by the block and the coefficient of friction. There is also a mention of the need to consider the work done by friction in the context of the block's motion up and down the incline.
lepton123
A block is projected up an inclined plane that makes an angle
θ to the horizontal. It returns
to its initial position with half its initial speed. What is the coefficient of kinetic friction
between the block and the plane in terms of the angle of the incline?
Not sure?
I know that generally, the co-efficient is tanθ, and I know how to derive that, but I am unsure what to do here
Try to set up the equation for the mechanical energy of the system.
Remember to include the work of friction.
You have essentially TWO unknows in this problem, the height the block attains, and the coefficient of friction.:
Use the energy equation twice, one for comparing initial mechanical energy relative to position of maximal height (where you know the velocity is 0), and the second when the block has returned.
And no, the kinetic friction coefficient (mu) is NOT generally equal to tan(theta).
The coefficient for maximal STATIC friction, though, can be estimated by the SLIP ANGLE "theta" by that formula.
What do you mean the work energy theorem? Are you referring to Wnet=change in Kinectic energy, and if so, then the change from the start at the bottom to the end when its at the bottom again? How do I involve friction into this?
Yes, I mean the work-energy theorem.
The frictional force will yield a net work, even though the block returns to its initial position.
In terms of θ, what is the normal force acting on the block? In terms of θ and μ (coefficient of kinetic friction), what is the frictional force acting on the block? If the block moves up the plane a distance L (where it stops), how much work does the frictional force do on the block? If the block has an initial velocity v0 and it stops after a distance L, what is its change in kinetic energy? What is its change in potential energy. How is the distance L related to v0, μ, and θ? How much frictional work has been done after the block has gone up the plane and come back down to its original position? What is the change in potential energy. If its final velocity is half its initial velocity up the plane, what is its change in kinetic energy? What coefficient of kinetic friction required to make all this happen?
"how much work does the frictional force do on the block?"
How do you find this?
If the block travels a total distance s, and throughout that travel its movement has been opposed by a frictional force F, how much work has been done against friction?
Well, the frictional force is a CONSTANT! Then the work is easy to set up.
Set up the work energy theorem for the two nstances:
1.Start versus at maximal height
2. Maximal height versus return position.
(The work from friction will NOT cancel if you set up this properly!)
you have been told WHAT to do, several times over in this thread.
Now, DO it, rather than anything else.
Let's see you answer my first two questions first before you address this question. If you can't answer them, then you will not be answer this question.
  • · Replies 16 ·
  • · Replies 21 ·
