What is the correct formula for refraction at an interface between two media?
22 replies · 4K views
Chuck Berry Rules
Hi!
I have a problem understanding what happens when a plane electromagnetic wave hits a surface consisting of two medias of different optical density.
My old school litterature tells me two formulas which I really don't understand where they come from.
The same teacher starts by telling me these facts:
1) E1t=E2t
2) H1t=H2t
3) D1n=D2n
4) B1n=B2n
where n stands for normal to the surface and t stands for tangential to the surface.
In my drawing I have tried to use 1 and 3 to wind up with my teacher's curious formulas like
[tex]\frac{E_{rn}}{E_{1n}}=-\frac{sin(\theta_1-\theta_2)}{sin(\theta_1+\theta_2)}...1.1[/tex]
and
[tex]\frac{E_{rt}}{E_{1t}}=\frac{tan(\theta_1-\theta_2)}{tan(\theta_1+\theta_2)}...1.2[/tex]
but I get a totally different answer like for instance for the tangential part
[tex]E_1sin(\theta_1)=E_2sin(\theta_2)+E_rsin(\theta_r)...1.3[/tex]
which may be rewritten as
[tex]\frac{E_{rt}}{E_{1t}}=\frac{E_rsin(\theta_r)}{E_1sin(\theta_1)}=\frac{E_1sin(\theta_1)-E_2sin(\theta_2)}{E_1sin(\theta_1)}...1.4[/tex]
or
[tex]\frac{E_{rt}}{E_{1t}}=\frac{E_rsin(\theta_r)}{E_1sin(\theta_1)}=1-\frac{E_2sin(\theta_2)}{E_1sin(\theta_1)}...1.5[/tex]
which isn't even close to my teacher's formula.
So what am I doing wrong?
Roger
PS
I like complex numbers and by using them I kind of think that my failure of understanding might not be regarding the physics but regarding the math, my thoughts goes like this:
[tex]K=\frac{E_{rt}}{E_1}=1-\frac{E_2sin(\theta_2)}{E_{1t}sin(\theta_1}...2.3[/tex]
Here I have tried to comply with my teacher's formula by testing this
[tex]K\approx 1-\frac{e^{j\theta_2}}{e^{j\theta_1}}=1-e^{j(\theta_2-\theta_1)}...2.4[/tex]
Here I am guessing wildly and state that there can be no single real 1 in a complex number, which makes
[tex]K\approx e^{j(\theta_2-\theta_1)/2}(e^{-j(\theta_2-\theta_1)/2}-e^{j(\theta_2-\theta_1)/2})...2.5[/tex]
or
[tex]K\approx -2je^{j(\theta_2-\theta_1)/2}\frac{(e^{j(\theta_2-\theta_1)/2}-e^{-j(\theta_2-\theta_1)/2}}{2j}...2.6[/tex]
which equals
[tex]K\approx -2je^{j(\theta_2-\theta_1)/2}sin((\theta_2-\theta_1)/2)...2.7[/tex]
where we have a constant (complex) amplitude which only varies in phase and has been added 90 degrees in phase due to j, in any case the substraction of the angles is here correct and I am starting to wonder if the transponate also should be considered and in that case perhaps it "stays" in the nomenator of 2.4 which would yield
[tex]K\approx -2je^{j(\theta_2-\theta_1)/2}\frac{sin((\theta_2-\theta_1)/2)}{sin((\theta_2+\theta_1)/2)}...2.8[/tex]
still, I only get half the angles and it should also read tangens.
This is the best I can do about this, I have given up so please help.
Those initial equations relating the parallel and tangential components are the boundary conditions for the fields. The fields are discontinuous between different media and are related across the boundary by those conditions. The forms you have how are in the case that there is no free charge density or current density. They are derived form Maxwell's equations.
I see a number of things wrong here. You absolutely cannot try to work backward from your teacher's answer. You need to go through the derivation logically and step by step starting with the boundary conditions. The form your teacher has arises much later in the derivation after an approximation and then an application of Snell's Law to the Fresnel equations, but you haven't even derived the basic set of equations yet and so you are far from getting that form. At this stage, you should still have several of the important constants around and cosines from the tangential and parallel projections, not sines.
Also, your work with the complex exponentials is wildly off, so I suggest using the regular trig form for the time being and then reviewing complex numbers when you get a chance. You absolutely cannot get rid of the real numbers in your equations just because you're using the complex representation of trig functions.
Perhaps I should not write any answer but I like to write in the english langage.
I thank you for your answer, it was educational.
I study physics on my own spare time and it was 21 years ago when I got my Master's degree in Electronic Engineering but I have been sick in my head for quite some time and has lost almost all of my knowledge, now I am just trying to get the most interesting part back and it feels like I am beginning from zero.
I love the book Field and Wave Electromagnetics (Cheng) and I will reread it when I'm finished with my teacher's book.
While Cheng explains and derives the bondary equations I feel I do not really have to know how they are derived right now, but I do need to know the next step that is how the tangential and normal bondary equations gives rise to the formulas we are discussing because if I don't understand how the equations are derived then there is really no point in continuing studying, at least this is my point of view.
In other words, I can accept the bondary conditions but I can not accept the sine/tangens equations without knowing how they are derived.
If I can not get to understand these equations and how they are derived, I will skip studying optics totally (and move on to Fluid Mechanics).
It was interesting to hear that I just can't get rid of a real number in a complex expression, but if you consider frequency components like in a mixer
[tex]Ae^{jw_1t}*Be^{jw_2t} \propto e^{j(w_1+w_2)t}...2.9[/tex]
that is that the sum terms fall out directly BUT we know (and use) the difference terms also and where did they go? They come from the transponate i.e
[tex]Ae^{jw_1t}*Be^{jw_2t^*} \propto e^{j(w_1-w_2)t}...2.10[/tex]
so the proper expression is
[tex]Ae^{jw_1t}*Be^{jw_2t} \propto e^{j(w_1+/-w_2)t}...2.11[/tex]
and in the same time the fundamentals are also there that is that the number of frequencies are w1, w2, w1+w2 and w1-w2 ant the complex analize is complete (but not without the transponate).
Remember that all this is just what i believe.
Roger
I think I now understand a small part of the problem, the incident "beams" have ortogonal field vectors (EXB) which is what the bondary equations actually referes to so my sine really turns to cosine as RedDelicious says above.
This gives me
[tex]E_{1y}cos(\theta_1)=E_{2y}cos(\theta_2)-E_{ry}cos(\theta_1)[/tex]
[tex]\frac{E_{ry}}{E_{1y}}=\frac{E_{2y}cos(\theta_2)}{E_{1y}cos(\theta_1)}-1[/tex]
How far from the truth am I now?
Roger
This gives me
Roger
I'm not following what you're doing. What about the boundary conditions?
For example, let's take a look at the case of perpendicular incidence.
From the boundary condition for the magnetic field, we know that the tangential component must be continuous.
[tex]-\frac{B_i}{\mu_i}\cos{(\theta_i)}+\frac{B_r}{\mu_i}\cos{(\theta_r)}=-\frac{B_t}{\mu_t}\cos{(\theta_t)}[/tex]
We can relate this to the respective E components by,
[tex]B_i = \frac{E_i}{v_i}<br /> \\<br /> B_r = \frac{E_r}{v_r}<br /> \\<br /> B_t=\frac{E_t}{v_t}[/tex]
For the incident and reflected portions, we know that [itex]v_i = v_r[/itex] and [itex]\theta_i = \theta_r[/itex] because they're in the same medium. and so we then have
[tex] <br /> \frac{1}{\mu_i v_i}(E_i-E_r)\cos{(\theta_i)}=\frac{1}{\mu_t v_i}E_t \cos{(\theta_t)}<br /> [/tex]
However at the interface y = 0, the E field of the plane waves will have the same cosine arguments and so
[tex] <br /> \frac{n_i}{\mu_i}(E_{0i}-E_{0r})\cos{(\theta_i)}=\frac{n_t}{\mu_t}E_{0t} \cos{(\theta_t)}<br /> [/tex]From here you can solve for the amplitude ratios and use the approximation that [itex]\mu_i \approx \mu_t \approx \mu_0[/itex].
See if you can reduce it. If done correctly, applying Snell's law after will yield the first equation in your original post.
The parallel case follows in a similar manner.
I can't begin to describe how thankful I feel for you taking the time and effort into explaining this to me.
I am very happy!
However, I do think I see two faults in your nice explanation but they are minor faults but they made me, who does not understand so well, confused:
The signs in this equation does not follow my Poynting vectors:
[tex]-\frac{B_i}{\mu_i}\cos{(\theta_i)}+\frac{B_r}{\mu_i}\cos{(\theta_r)}=-\frac{B_t}{\mu_t}\cos{(\theta_t)}...3.1[/tex]
They should be negated if I am to understand anything, actually you do just that later on in this formula (E=vB)
[tex]\frac{1}{\mu_i v_i}(E_i-E_r)\cos{(\theta_i)}=\frac{1}{\mu_t v_i}E_t \cos{(\theta_t)}...3.2[/tex]
but the "real" and confusing (obs) fault is in the right side of that formula which should read
[tex]\frac{1}{\mu_t v_t}E_t \cos{(\theta_t)}...3.3[/tex]
which is just some small misstake from your side, right?
Otherwise I could actually follow you (after a while), the part where vB=E was interesting to relearn because my teacher spoke of it recently in the littarature, I had just not fully understood it, obviously, but I could follow you there but the use of refraction index (or what's it called) got me confused for a while but I soon realized that v=c/n where c conveniently disappears from the formula.
Thank you for leaving some "homework" for me but I doubt that I will be able to solve it even from here.
However, I will for certain try but if the reduction comes before Snell I doubt that I will be able to solve it.
Roger
I am very happy!
Roger
The signs are that way because for light incident from the right, the tangential component of the magnetic field points leftward for the incident and transmitted wave. The reflected wave is of course the opposite. The standard convention is to have light coming from the left and +x to the right, and so those components are negative, and the reflected is positive. The signs should work out even if you do it differently so long as you are consistent. I can't see your diagram.
Yes, you are correct. It should be.
[tex]\frac{1}{\mu_t v_t}E_t \cos{(\theta_t)}[/tex]
You otherwise wouldn't get the correct index of refraction for nt on the right hand side.
I actually meant to include a note about the v=c/n part because I realized it wasn't obvious where the index of refraction came from, but I apparently forgot, so I'm glad you were still able to figure that out.
Okey, let's try to use what I've learned
[tex]\frac{n_i}{\mu_i}(E_i-E_r)\cos{(\theta_i)}=\frac{n_t}{\mu_t}E_t \cos{(\theta_t)}...4.1[/tex]
This equation comes from 3.2 above when v=c/n is considered, then we have
[tex]\mu_i\approx \mu_t...4.2[/tex]
which yields
[tex]n_i(E_i-E_r)\cos{(\theta_i)}=n_tE_t \cos{(\theta_t)}...4.3[/tex]
rearranging gives
[tex]n_iE_r\cos{(\theta_i)}=n_iE_i\cos{(\theta_i)}-n_tE_t\cos{(\theta_t)}...4.4[/tex]
that is
[tex]\frac{E_r\cos(\theta_i)}{E_i\cos(\theta_i)}=\frac{E_r}{E_i}=1-\frac{n_tE_tcos\theta_t}{n_iE_i\cos{\theta_i}}...4.5[/tex]
using Snell's Law
[tex]n_i\sin{\theta_i}=n_t\sin{\theta_t}...4.6[/tex]
we get
[tex]\frac{E_r}{E_i}=1-\frac{n_i\frac{sin(\theta_i)}{sin(\theta_t)}E_tcos(\theta_t)}{n_iE_icos(\theta_i)}...4.7[/tex]
or
[tex]\frac{E_r}{E_i}=1-\frac{E_t\cot(\theta_t)}{E_i\cot(\theta_i)}...4.8[/tex]
This is the first time in my life I have used cotangens, also it does not comply with my teacher's formula.
Roger
which yields
rearranging gives
that is
using Snell's Law
we get
or
Roger
You're going to want to use the fact that [itex]E_{0i}+E_{0r}=E_{0t}[/itex] at the boundary. From there, it will be a simple exercise in algebra to find the ratios.
Also, for the Snell's law simplification, you're going to want to have your equation in a form where you can see to use the sum and difference identities for sine, meaning everything in terms of sines and cosines.
It is late and I am soon going to bed but I will try a reply (thanks for your reply, by the way):
Using 4.8 and your statement that
[tex]E_i+E_r=E_t...5.1[/tex]
where I have skipped the zero in the indexing because it is only hard work codfing for it while we are discussing the bondary anyway.
Also, I would like to rewrite this equation of yours as
[tex]E_i-|E_r|=E_t...5.2[/tex]
because isn't this what's it all about?
The differense in incoming and reflected energy is the transmitted energy like the energy density
[tex]w_E=\frac{1}{2}\epsilon E^2...[J/m^3]...5.3[/tex]
that is, we have E squared "everywere" so that energy is lost in reflection but the rest is transmitted.
Getting back to 4.8 and your statement, we have
[tex]\frac{E_r}{E_i}=1-\frac{E_t\cot(\theta_t)}{E_i\cot(\theta_i)}=1-\frac{(E_i+E_r)\cot(\theta_t)}{E_i\cot(\theta_i)}...5.4[/tex]
or
[tex]\frac{E_r}{E_i}=1-\frac{\cot(\theta_t)}{\cot(\theta_i)}-\frac{E_r\cot(\theta_t)}{E_i\cot(\theta_i)}...5.5[/tex]
Still far from my teacher's formula.
Roger
Ei−|Er|=Et...5.2Ei−|Er|=Et...5.2​
E_i-|E_r|=E_t...5.2
No. The need for continuity in the tangential components at the boundary rules that form out. Your equations need to obey the boundary conditions. Physically, if you start from the beginning with your plane wave construction, it might make more sense if you think in terms of the combined waves on the left (reflected and incident) will join at the boundary and should equal the combined wave on right right (transmitted) indicating to sum them. You shouldn't worry about energy until you have the correct equations for the fields because you still need to find them to find the fields anyway. Your algebra is wrong there as well. Even if you took that approach, which you shouldn't, that's not the equation you'd get.
You should start over from your equation 4.3 making the substitution in my last post and then solve for the ratio. I'm also going to repeat my very strong suggestion of keeping everything in terms of sines and cosines. You're not going to get anywhere you're using cotangents. You want to keep it in terms of sines and cosines so that it's clear to use the sum and difference identities for sine.
The form you want to end up with is.
[tex]\left(\frac{E_{0r}}{E_{0i}}\right)_\perp = \frac{n_i \cos(\theta_i)-n_t \cos(\theta_t)}{n_i \cos(\theta_i)+n_t \cos(\theta_t)}[/tex]
From here you can easily apply Snell's law, do a little algebra, and then use the sum and difference identity for sine to get your teacher's form.
Thank you very much for your answer!
I will have think some about this before I get back to you with a serious answer but I can tell you that one kind of strange thing that my teacher told me about a rope reflecting against a wall (denser media, obviously) is that the calculation of the waves goes like this
[tex]s_i(x,t)=Asin(wt-kx)...6.1[/tex]
and
[tex]s_r(x,t)=Asin(wt+kx+\phi)...6.2[/tex]
and at x=0 there can be no disturbance (s) so that
[tex]s_i+s_r=0...6.3[/tex]
which both gives that
[tex]\phi=\pi...6.4[/tex]
AND that the incident wave and reflected wave are added which I feel is hard to grasp, I see an incoming wave and a reflected wave totally separated, I don't see them both, how could I?
I can however accept that it is this way not to torture you anymore, and get down to the hints you have given me.
Give me a day or two :)
Roger
I will now give it another try.
Copying 4.3:
and using your tip
[tex]E_{0i}+E_{0r}=E_{0t}...7.1[/tex]
which I, for simplicity, rewrite as
[tex]E_i+E_r=E_t...7.2[/tex]
using this in 4.3 gives
[tex]n_i(E_i-E_r)\cos{(\theta_i)}=n_t(E_i+E_r)\cos{(\theta_t)}...7.3[/tex]
which means
[tex]n_iE_i\cos{(\theta_i)}-n_tE_i\cos{(\theta_t)}=n_tE_r\cos{(\theta_t)}+n_iE_r\cos{(\theta_i)}...7.4[/tex]
so that
[tex]\frac{E_r}{E_i}=\frac{n_i\cos{(\theta_i)}-n_t\cos{(\theta_t)}}{n_t\cos{(\theta_t)}+n_i\cos{(\theta_i)}}...7.5[/tex]
I now thankfully got your formula which I only think I understand, yet it does not comply with my teacher's formula.
Perhaps I am only lacking trigonometric skills?
Roger
All you have to do to get your teacher's form from here is apply Snell's law and simplify. Since you've arrived at the main result, for closure, I will go ahead and carry out the last calculation.
By Snell's Law, we have that
[tex] n_i\sin{(\theta_i)} = n_t\sin{(\theta_t)}<br /> \\~\\<br /> n_i = n_t \frac{sin{(\theta_t)}}{sin{(\theta_i)}}[/tex]
Substituting into (7.5),
[tex] \left(\frac{E_{0r}}{E_{0i}}\right)_\perp= \frac{ n_t \frac{sin{(\theta_t)}}{sin{(\theta_i)}}\cos{(\theta_i)}-n_t\cos{(\theta_t)} }{ n_t \frac{sin{(\theta_t)}}{sin{(\theta_i)}}\cos{(\theta_i)}+ n_t\cos{(\theta_t)}}[/tex]
nt can be factored out the numerator and denominator and cancel out.
Multiplying the numerator and denominator by [itex]\sin{(\theta_i)}[/itex]
[tex] <br /> = \frac{\sin{(\theta_t)}\cos{(\theta_i)}-\cos{(\theta_t)}\sin{(\theta_i)}}{\sin{(\theta_t)}\cos{(\theta_i)}+\cos{(\theta_t)}\sin{(\theta_i)}}<br /> [/tex]
By the sum and difference identities for sine, we have that
[tex] \sin{(x+y)} = \sin{x}\cos{y}+\sin{y}\cos{x}<br /> \\~\\<br /> \sin{(x-y)} = \sin{x}\cos{y}-\sin{y}\cos{x}[/tex]
Paying careful attention to the order of [itex]\theta_i[/itex] and [itex]\theta_t[/itex], we get that
[tex] = \frac{\sin{(\theta_t-\theta_i)}}{\sin{(\theta_i+\theta_t)}}<br /> \\~\\<br /> = -\frac{\sin{(\theta_i-\theta_t)}}{\sin{(\theta_i+\theta_t)}}[/tex]
Which is the form your teacher has.
Dear RedDelicious!
I am sorry to say that I kind of forgot Snell's Law in the middle of all the algebra.
I am ashamed about that, very stupid of me!
I really saw that pure trigonometrics wouldn' solve it for me but just right there I actually thought so.
I thank you very much for taking the time and effort into spelling it out for me especially the details regarding trigonometric identities which I of course could have looked up by myself, I think I understand it all now and maybe I will give it at try for the normal components also, now that you so thankfully have showed me how to do.
On the other hand, this shows a clear path to my teacher's formulas so now I think I just can accept the other one.
But maybe that is just lazyness? :)
Roger
I wish to try to derive the other (parallell?) formula also.
First, I am very confused about the denotion of parallell/perpendicular, my teacher tells me that parallell is actually parallell to the normal of the bondary, this sounds very strange but if I quote him he says "perpendicular means the component of the electrical intensity which is perpendicular to the plane which is defined by the bondary normal".
So to me this sounds like "perpendicular" is actually parallell and "parallell" is actually perpendicular, very confusing indeed.
Anyway let's try do derive the "other" formula.
First I thought that I could use your formula
[tex]\left(\frac{E_{0r}}{E_{0i}}\right)_\perp= \frac{ n_t \frac{sin{(\theta_t)}}{sin{(\theta_i)}}\cos{(\theta_i)}-n_t\cos{(\theta_t)} }{ n_t \frac{sin{(\theta_t)}}{sin{(\theta_i)}}\cos{(\theta_i)}+ n_t\cos{(\theta_t)}}...8.1[/tex]
and just change it like
[tex]\left(\frac{E_{0r}}{E_{0i}}\right)_\perp= \frac{ n_t \frac{sin{(\theta_t)}}{sin{(\theta_i)}}\sin{(\theta_i)}-n_t\sin{(\theta_t)} }{ n_t \frac{sin{(\theta_t)}}{sin{(\theta_i)}}\sin{(\theta_i)}+ n_t\sin{(\theta_t)}}...8.2[/tex]
but this does obviously not work so let's begin from the beginning:
[tex]E_i\epsilon_i\sin{(\theta_i)}+E_r\epsilon_i\sin{(\theta_r)}=E_t\epsilon_t\sin{(\theta_t)}...8.3[/tex]
and if still
[tex]E_i+E_r=E_t...8.4[/tex]
then
[tex]E_i\epsilon_i\sin{(\theta_i)}+E_r\epsilon_i\sin{(\theta_r)}=(E_i+E_r) \epsilon_t\sin{(\theta_t)}...8.5[/tex]
or
[tex]E_i(\epsilon_i\sin{(\theta_i)}-\epsilon_t\sin{(\theta_t)})=E_r(\epsilon_t\sin{(\theta_t)}-\epsilon_i\sin{(\theta_i)})...8.6[/tex]
so that
[tex]\frac{E_r}{E_i}=\frac{\epsilon_i\sin{(\theta_i)}-\epsilon_t\sin{(\theta_t)}}{\epsilon_t\sin{(\theta_t)}-\epsilon_i\sin{(\theta_i)}}...8.7[/tex]
or
[tex]\frac{E_r}{E_i}=-\frac{\epsilon_i\sin{(\theta_i)}-\epsilon_t\sin{(\theta_t)}}{\epsilon_i\sin{(\theta_i)}-\epsilon_t\sin{(\theta_t)}}...8.8[/tex]
I obviously don't understand a thing :D
Roger
Perhaps more clearly, it is when [itex]\vec{E}[/itex] is parallel and when it is perpendicular to the plane of incidence. You need to draw a diagram, or at the least, find one to look at. That should clarify the difference as well as to help you set up your equations.
Take a look at the diagram here
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/freseq.html
Before trying this second part, you really need to work the first problem again but starting from the absolute beginning. Start with just your general plane waves and a diagram and see if you can correctly apply the boundary conditions and arrive at the answer. Make sure you can physically justify each step along the way.
After you've done that, if you want to give the second part another shot. You should find that
[tex] <br /> \left(\frac{E_{0r}}{E_{0i}}\right)_\parallel = \frac{n_t\cos{(\theta_i)}-n_i\cos{(\theta_t)}}{n_t\cos{(\theta_i)}+n_i\cos{(\theta_t)}}<br /> [/tex]
Please really give it some thought now that you have an idea of the mathematical framework. Your current approach to the second part is completely wrong.
Dear RedDelicious!
I just want to thank you for that link, it has given me a clear picture of what is parallell and what is perpendicular (actually my interpretation of my teacher's learning was somewhat right, parallell and perpendicular are related to the normal of the interface or as you call it, plane of incidence).
I will derive the first formula again and I won't disturb you until I think I understand both the physics and the math of it all.
I think I will even study where the bondary equations come from (Maxwell's Equations), I have a nice book on the subject (Cheng).
Merry Christmas!
Roger
Merry Christmas!
Roger
As always, don't hesitate to ask any questions. This is a good problem because it involves a number of core concepts, but that is also what can make it hard.
Merry Christmas!
When I uploaded the drawing the system somehow failed to upload my text also (it wasn't much though).
Anyway, I wish to use my drawing and emphasize certain points:
An incident plain wave may be written
[tex]E_{iy}=E_{iy0}sin(wt-kx)...9.1[/tex]
In the drawing, this is the part parallel to the normal of the interface and it is called "parallel"
The perpendicular part does only exist if the wave is circularly polarized like
[tex]E_{iy}=E_{iy0}sin(wt-kx)...9.2[/tex]
[tex]E_{iz}=E_{iz0}cos(wt-kx)...9.3[/tex]
which only is a special case of elliptically polarized waves.
In this case we have a plane wave (i.e its electrical field is in one plane only, in this case the xy-plane) so that the discussion regarding what happens in the parallel plane (parallel to the plane of incidence) is also valid for the perpendicular plane but only if we consider a perpendicular polarized wave, right?
In other words, we do not consider circular or elliptical polarized waves here, only plane waves, right?
Because if this isn't right I really do not understand a thing.
Happy New Year!
Roger
Just trying to understand...
For the parallel part we have
[tex]E_{i\parallel}=E_{in}=E_{iy0}sin(\theta_i)=E_isin(\theta_i)[/tex]
where the last equality is just to be conform with earlier discussions.
For the perpendicular part we have
[tex]E_{i\perp}=E_{it}=E_{iz0}cos(\theta_i)=E_icos(\theta_i)[/tex]
where one might see the perpendicular part as strictly being mirrored into the tangential part of the interface, I don't really know what I am talking about here but it is simple to see the parallell part but not the perpendicular part yet draw some kind of conclusion that the perpendicular part then should lay in the tz-plane.
Except for my amateur speculation I think I now got this part correctly, please tell me if I'm wrong.
From Maxwell we then have
1) E1t=E2t
2) H1t=H2t
3) B1n=B2n
4) D1n=D2n
These I will look up why they are as they are but right now I will accept them as is.
Looking at the interface and thinking energy conservation I get
[tex]E_i-Er=Et[/tex]
The E-fields should be squared but the principle is the same, I think (obs).
Using
[tex]\theta_r=\theta_i[/tex]
we then get for the perpendicular part
[tex]E_icos(\theta_i)-Ercos(\theta_i)=E_tcos(\theta_t)[/tex]
and for the parallell part we have
[tex]E_isin(\theta_i)-Esin(\theta_i)=E_tsin(\theta_t)[/tex]
But this is wrong, right?
Time for late supper, good night!
Roger
PS
If it wasn't for you I would not know how to code for perp an parallel :)
Let's begin from the beginning and use proper formulas
For the parallel part:
[tex]E_{i\parallel}=E_{in}=E_{iy0}sin(\theta_i)=E_isin(\theta_i)...10.1[/tex]
which we rewrite as
[tex]E_{i\parallel}=E_isin(\theta_i)...10.2[/tex]
and for the perpendicular part we do the same and write
[tex]E_{i\perp}=E_icos(\theta_i)...10.3[/tex]
Now we know that the perpendicular part is in the interface plane, this means that we have to use
[tex]H_{1t}=H_{2t}...10.4[/tex]
but why can't we use
[tex]E_{1t}=E_{2t}...10.5[/tex]
Anyway, using 10.3 and 10.4 gives
[tex]H_icos(\theta_i)-H_rcos(\theta_i)=H_tcos(\theta_t)...10.6[/tex]
or
[tex]H_rcos(\theta_i)=H_icos(\theta_i)-H_tcos(\theta_t)...10.7[/tex]
while
[tex]B=\mu H...10.8[/tex]
we have
[tex]\frac{B_r}{\mu_i}cos(\theta_i)=\frac{B_i}{\mu_i}cos(\theta_i)-\frac{B_t}{\mu_t}cos(\theta_t)...10.9[/tex]
now
[tex]E=vB...10.10[/tex]
such that
[tex]\frac{E_r}{v\mu_i}cos(\theta_i)=\frac{E_i}{v\mu_i}cos(\theta_i)-\frac{E_t}{v\mu_t}cos(\theta_t)...10.11[/tex]
now
[tex]v=\frac{c}{n}...10.12[/tex]
which gives
[tex]\frac{n_rE_r}{c\mu_i}cos(\theta_i)=\frac{n_iE_i}{c\mu_i}cos(\theta_i)-\frac{n_tE_t}{c\mu_t}cos(\theta_t)...10.13[/tex]
or
[tex]\frac{n_rE_r}{\mu_i}cos(\theta_i)=\frac{n_iE_i}{\mu_i}cos(\theta_i)-\frac{n_tE_t}{\mu_t}cos(\theta_t)...10.14[/tex]
using
[tex]\mu_t\approx \mu_i...10.15[/tex]
gives
[tex]n_rE_rcos(\theta_i)=n_iE_icos(\theta_i)-n_tE_tcos(\theta_t)...10.16[/tex]
using
[tex]n_r=n_i...10.17[/tex]
gives
[tex]n_iE_rcos(\theta_i)=n_iE_icos(\theta_i)-n_tE_tcos(\theta_t)...10.18[/tex]
dividing this with
[tex]n_iE_icos(\theta_i)...10.19[/tex]
gives
[tex](\frac{E_r}{E_i})_\perp =1-\frac{n_tE_tcos(\theta_t)}{n_iE_icos(\theta_i)}...10.20[/tex]
using Snell's Law like
[tex]n_i=\frac{n_tsin(\theta_t)}{sin(\theta_i)}...10.21[/tex]
we get
[tex]?[/tex]
Am I close or far from it?
Roger
PS
I think I should inject your amazing formula
[tex]E_{0i}+E_{0r}=E_{0t}[/tex]
here but that equation is really hard to understand because how can there be a sum of electric field intensities when the wave is going away from the interface? Maybe one can see it as the total electric field intesity being the same on both sides of the bondary? Like there is a potential that needs to be the same regardless if one travels inside or outside of the bondary?
