What is the correct way to name alkanes with multiple branches?
  • Thread starter Thread starter Suzyscans
    Nomenclature
The discussion focuses on the correct naming of alkanes with multiple branches. The first problem is identified as 2,3-dimethylbutane, while the second is named 2-butyl-3-ethylbutane. The third problem involves an 8-carbon chain with branches at C3 and C4, leading to confusion about the correct nomenclature. The proposed name for the third problem is questioned, with a suggestion of 4-ethyl-4,3-dimethyloctane. The thread highlights the complexities of alkane naming conventions and the need for clarity in identifying branches.
Suzyscans
1. This is my first posting, I am having trouble naming alkanes. I believe my first two problems are correct, but am unsure. The third problem I am having trouble with. I am just not sure what to name the branches coming off the carbon chain.
2.
1. (CH3)2CHCH(CH3)2 2. CH2Ch2CH2CH3
l
CH3CH2CH2CHCH2C--H
l l
CH3CH2 H3.
CH3 H
l l
CH3CH2CH2CH2--C--C--CH2CH3
l l
CH2 CH3
l
CH3
3. Problem 1 :4-carbon chain makes it butane. The branches at both C2 and C3 are methyl, so the name is 2,3-dimethylbutane.
Problem 2: 6-carbon chain makes it hexane. The branch at C2 is butyl. The branch at C3 is ethyl, so the name is 2-butyl-3-ethylbutane.
Problem 3:
8-carbon chain= octane
branch at C3 is methyl
branches at 4C are methyl and ethyl
That is where I get stuck on the name. Is it 4-ethyl-4,3-dimethyloctane??
Thanks very much for your input!
I can't get the equations to display properly! I will edit as soon as I figure it out :)
You have 1) correct.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
