Does Light Have a Measurable Density?
  • Context: Undergrad
  • Thread starter Thread starter Niflheim
    Density Light
The discussion centers on the concept of light's density, specifically addressing whether light, as composed of massless photons, possesses measurable density. Participants clarify that while photons have zero rest mass, they can exhibit energy density and number density when considered in bulk. The energy density of light is defined by the equation eps0/2 A^2 ω^2, where A is the amplitude of the electric field and ω is the angular frequency. The conversation also touches on the implications of light's properties on its interactions with matter and energy.
  • Understanding of photon properties and behavior
  • Familiarity with concepts of energy density and number density
  • Basic knowledge of electromagnetic theory
  • Awareness of wave-particle duality in quantum physics
  • Research the concept of energy density in electromagnetic fields
  • Study the implications of wave-particle duality on light behavior
  • Explore the relationship between frequency and energy in photons
  • Investigate the effects of light confinement in resonant cavities
Physics students, researchers in quantum mechanics, and anyone interested in the fundamental properties of light and its interactions with matter.
Niflheim
What is the density of light?
I'm relatively new to Physics and very new to the forum, so please forgive any (potentially) hilarious mistakes or stupidity in my question, knowledge, and use of the thread.
But really, what is the density of light? Light is a particle like anything else, and all particles have a density, so what is it? How does it impact light's interactions with matter/energy/fields? Are any of light's properties dependent on its density? Do different light particles have different densities? Any answers/insight would be greatly appreciated.
Thanks for any/all replies!
Science news on Phys.org
Welcome to PF!
If you are talking about mass density, no, light does not have mass so it doesn't have density.
Thanks!
When you say that light has no mass, do you mean literally, or in the same way that we say the electron adds no mass to an atom? If the former, than how can it exist as a particle without mass? Is the particle just a grouped together bunch of light waves or something?
Photons are among the gauge bosons with zero invariant mass. Electrons have mass 0.511 MeV/c^2, 9.10×10−31 kg
Interesting. And yes I know electrons have mass, I thought you meant that they had a near zero mass.
Thanks so much for the replies! I'm off to look into the zero mass particles now, they seem interesting.
You might want to read about wave-particle duality to expand your understanding.
Niflheim said:
Thanks!
Electrons do add mass to an atom. Who told you they do not ?
The mass of neutral protonic hydrogen is m_p+m_e - Eb.
One could say that the electron adds anything between m_e and m_e - Eb, slightly less than m_e.
Note that m_p ~ 2000 times m_e, so the addition is small.
Okay, just to clear things up a bit, yes guys, I know that electrons have mass. When I said that I was asking if he meant exactly zero mass or so close to zero as to be irrelevant, like how we don't add the mass of the electrons to an atom's mass number since it is mostly irrelevant.
Particles do not have a property "density". Density is something you can consider for a large amount of particles (like "the density of air molecules in the room" only. A volume with light inside will have a photon density (photons per volume) and an energy density (energy per volume).
It is expected that photons are exactly massless. If they have mass (you can never measure something exactly), it has to be extremely tiny.
Two more things:
- There are several properties of light that can be termed density. Energy-momentum density (including, energy density, momentum density, energy transport density, stress density), angular momentum density (orbital and spin). number density (but this is just the same as energy density).
- Imagine a massless resonator with an infinite quality value, containing a resonant electromagnetic field.
Such an object would have a purely electromagnetic mass. Thus confined light can have mass, the density of which is simply the energy density in the rest frame.
Thanks, that helps clear it up a bit.
Hello! I'm also new here, and I find this question very interesting.
Do we say photons have no mass because they are definitely massless? Or is it because their mass is so small that there is no device/method known to mankind yet that can measure to such a small degree?
Welcome to PF.
Photons are definitely* massless. Scientists speak with precise wording, so when someone says "massless", that's what they really mean.
*to within the limit of science's ability to say "definitely"
An incoming beam of coherent photons, when absorbed, will exert a force on the absorbing body similar to force of an incoming ball that is caught. It is possible to calculate this force, so in some ways, light behaves like moving massive particles, but its mass is entirely due to its energy and its energy is entirely due to its motion.
Wouldn't density be in direct relation to frequency... If measured in a beam of light wouldn't a higher frequency contain a higher density of photons than a lower frequency?
Higher frequency means that each photon is more energetic, not that there are more of them. Are you imagining photons arranged on a beam of light like a string of beads, all riding the beam, each one wavelength from the next? That picture would be wrong on multiple levels.
Hi my2cts,
Are you saying that if one can confine light, for instance, inside a cavity, it is possible to attach a rest mass to this oscillating electromagnetic field?
Could you please indicate some reference? It happens that I have great interest in this subject. Thank you in advance.
Best wishes,
DaTario
Photons have 0 rest mass, 0 inertia, 0 gravitational impact on matter. Perhaps the effect of the photonic fields leads to an increase in the mass of the matter it affects, but the fields themselves do not warp space in a gravitational sense.
It is possible to assign a mass to the whole system (cavity+radiation). This mass increases if you increase the amount of light in it, as the rest energy of the system increases.
Photons do have a gravitational impact on matter, because they have energy. They also have momentum.
So if we use a magnifying glass redirecting photons from a larger area to a smaller area would that increase density of photons at the focal point? You know the point where the ants catch fire.
Of course.
So if measured density at this focal point is based on the energy and momentum of the photons, and the frequency determines the energy and momentum of the photon...my question from earlier (#17)- Isn't photon density in direct relation to frequency? A higher frequency will take more energy and momentum creating a higher density at a measured point. Sorry, if I'm missing something basic just trying to understand.
But photons can't accelerate or decelerate. Their velocity remains the same regardless of "energy" they contain...
The density of the waves per distance increases with frequency, but a photon is still one photon. It can only land in one place.
You seem to be missing that a beam of light is not a single photon. Leaving aside the question of whether the notion of photons is useful in understanding light at this level (it is not), there are a lot of photons in a beam of light. More photons packed in a smaller area = higher light intensity in that area.
I agree a beam of light is not a single photon, didn't really question that, but my focus was more towards your final sentence "More photons packed in a smaller area = higher light intensity in that area." That basically says what I was saying, Photon Density(More photons packed in a smaller area) = Energy( higher light intensity in that area), my only addition is the "energy in the photon is directly associated with its wave frequency" (Planck-Einstein relation), then frequency is in direct relation to density.
That applies to a single photon.
What do you mean with the density of a photon?
If a beam light is combination of many photons, isn't the density is measured from the energy produced from the those photons.
  • · Replies 24 ·
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 20 ·
