What is the difference between terms and monomials in mathematics?
  • Thread starter Thread starter Smlevyy
    Terminology
The discussion clarifies that a monomial is a specific type of polynomial consisting of only one term, while the term refers to individual components in expressions. Terms can be separated by addition or subtraction, whereas monomials are products of numbers and variables. The conversation highlights the confusion between the two concepts, emphasizing that while all monomials are terms, not all terms are monomials. Examples provided illustrate the differences, such as monomials like 2x and polynomials like 2x-7. Understanding these distinctions is essential for mastering mathematical terminology.
Smlevyy
English's not the native language in my country; however (strangely), currently I'm learning Math in the language. And now I'm encountered with a kind of "language" problem here: I can't see the difference between the defination " term" and " monomials". Do they mean the same thing, but only have different emphasis? If so, which of them is used more often? Thank you if you could give me some ideas about this!
Mathematics news on Phys.org
Polynomials are made up of terms. These all have exponents of 0, 1, 2, ...
A monomial is a polynomial with one term:
y=2x
y=x^2
y=6
A binomial is a polynomial with two terms:
y=2x-7
y=x^2+3x
etc...
As far as I know, the values you sum over in a summation are called 'terms':
e.g.: a+b+c+d
a,b,c and d are called terms.
Just like for a product: abcd
the values are called 'factors'
English is not my native language either though...
Could you maybe give a sentence from your book for each word so we can see the context?
"Terms are separated by + or - "
"Monomial is a product of two or some factors, each of them is either a number, or a letter, or a power of a letter. A single number or a single letter may be also considered as a monomial."(defination from www.bymath.com)
But terms can be the same. (?) Sorry but I'm still a little confused.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
  • Sticky
11K
