What is the dimension of c3 in s=cs cos(c4t)
  • Thread starter Thread starter dovec
    Dimension
In the equation s = c3 cos(c4t), the left side represents a distance with the dimension of length [L]. The cosine function is dimensionless, which means that the right side must also equate to [L]. Therefore, the dimension of c3 must also be [L] to ensure both sides of the equation are consistent. This confirms that c3 has the same dimension as s, which is length. The discussion emphasizes the importance of dimensional analysis in validating equations.
dovec
Find the dimension for the quantity c3 in the expression s=c3 cos (c4t). Please someone help me solve this, s is a distance with unit L, t is a time with unit T and theta is an angle in radians.
The dimensions must be the same on both sides of a valid equation.
Left side you just have [L] Length.
Right side: cos(anything) is dimensionless, leaving just c3.
Thanks
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
