What is the domain for solving the equation √(5+x)-x=3 and writing down D(g)?
  • Thread starter Thread starter Jaco Viljoen
    Function
The discussion revolves around determining the domain of the function g(x) = √(5+x) - x and solving the equation √(5+x) - x = 3. The subject area includes algebra and functions, particularly focusing on square roots and their implications for real number outputs.
  • Participants explore the correct domain of g(x), questioning the original poster's assertion that x should be less than -5. There is a focus on ensuring that the square root function remains defined for real numbers.
There is an ongoing examination of the domain, with some participants pointing out the need for clarity regarding the conditions under which the square root is defined. Multiple interpretations of the domain have been discussed, and some participants have provided guidance on the implications of negative inputs for the square root function.
Participants note that the original poster's domain assertion was a typo, and there is a recognition that -5 should be included in the domain since √(0) is a real number. The discussion reflects a mix of corrections and confirmations regarding the domain and the conditions for real outputs.
Jaco Viljoen
g(x)=√(5+x)-x
a) Write down D(g)
b) Solve the equation
√(5+x)-x=3
√(5+x)-x=3
a)
x∈ℝ: x>-5
b)[/B]
√(5+x)-x=3
√(5+x)=x+3
(5+x)=(x+3)^2
(5+x)=(x+3)(x+3)
(5+x)=x^2+6x+9
x^2+5x+4=0
(x+4)(x+1)
x=-4 or x=-1
√(5-4)--4=3
√(1)+4=3 False
√(5-1)--1=3
2+1=3 True
x=-1
you can't take sqroot of 1 -1. sqrt(x^2)=|x|
Seems right. You haven't done a) though.
Oops, I've added my answer,
Thank you,
Thank you,
That's incorrect.(Assuming that you have the condition that the output must be real.) If x were to be less than -5, then you would have to take square roots of negative numbers, so your output would no longer be real.
For a) you wrote x<-5, that is the opposite of the domain.
Your solution was x = -1. That is not in x<-5.
I don't know what you meant, but your first sentence above is incorrect. 1 - 1 = 0, and ##\sqrt{0} = 0##.
I meant to say x>-5 so the root will not be of a negative number.
Yup, that's right.
Thank you,
Jaco Viljoen said:
g(x)=√(5+x)-x
a) Write down D(g)
√(5+x)-x=3
√(5+x)-x=3
a)
x∈ℝ: x>-5[/B]
You wrote that x should be less than -5. Can you take the square root of x-5 then? So what is the correct domain of g(x)?
b)
√(5+x)-x=3
√(5+x)=x+3
(5+x)=(x+3)^2
(5+x)=(x+3)(x+3)
(5+x)=x^2+6x+9
x^2+5x+4=0
(x+4)(x+1)
x=-4 or x=-1[/QUOTE]
Correct.
Jaco Viljoen said:
√(5-4)--4=3
√(1)+4=3 False
√(5-1)--1=3
2+1=3 True
x=-1
Correct.
Is x=-1 inside the domain?
I did fix this it was a typo
Yes it is
I
meant sqrt of 1 doesn't equal -1
The domain is not quite right. ##\ \sqrt{ 0 } \ ## is a real number, so -5 is in the domain.
You're right. I overlooked that fact. The inequality should be weak @Jaco Viljoen
  • · Replies 17 ·
