What is the domain of f(x)=x^(2/3)?
  • Thread starter Thread starter MSchott
    Domain
The domain of the function f(x) = x^(2/3) is all real numbers, as negative inputs yield positive outputs when squared, followed by taking the cube root. Some confusion arises from WolframAlpha suggesting the domain is all non-negative real numbers, which may stem from its interpretation of the function. The logarithmic transformation used in WolframAlpha implies that x must be greater than zero, excluding zero itself. However, since the cube root of a positive number is defined for all real values, the correct domain remains all real numbers. This highlights the importance of understanding different representations of the function.
MSchott
If I take a negative number and square it, the result is positive. For example, (-4)^2 is 16. The cube root is 16 is also a positive number. So I conclude that the domain of this function is "all real numbers". But in Wolfram the answer is "all non-negative real numbers". Where is my thinking going awry?
I don't think that a^{b/c} = \sqrt[c]{a^b} can be used when a is negative.
acabus: I am still having difficulty understanding. If "b" is an even power doesn't the negative "a" under the square root sign become positive?
You are correct - the domain of your function is all real numbers. The reason, I believe, that WolframAlpha gives a different domain is that it is converting x2/3 to a different form, using e as the base rather than x.
y = x2/3
=> ln(y) = (2/3) ln(x)
=> eln(y) = e(2/3)ln(x)
=> y = e(2/3)ln(x)
Now, x must be greater than 0. This is almost the same as what WA shows, except for zero.
Mark 44 Thank you so much.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
