Mentor
- 37,243
- 16,364
Umm, KE is also not fixed. It is based on a reference frame. I am sitting on my chair, so in the Earth's reference frame my KE is 0, but in the Sun's reference frame I am moving so I have a substantial KE.rogerk8 said:Ep is arbitrary chosen, right?
It is not fixed like Ek, right?
It is based on a reference point.
Energy is conserved regardless of which reference frame you use for KE and what reference point you use for PE, but different reference frames will give different values for KE and different reference points will give different values for PE.
Yes, if you choose the common convention of setting gravitational PE to 0 at infinity then at all finite distances the PE is negative. There is nothing wrong with that.rogerk8 said:But if Ep=0 at infinity, Ep might as well be negative, right?
I haven't been following your electrical PE stuff. Just like there are two masses in the gravitational equation there should also be two charges in the electrical one. If they have the same sign then the overall expression (using PE = 0 at infinity) is positive, indicating that it is repulsive. If they have opposite signs then the expression is negative, indicating that it is attractive. So the sign is folded into the charge. When the force is attractive, like gravity, you automatically get a negative sign for the PE, like gravity.rogerk8 said:The interesting thing here is that if we compare FGPE with EPE the major difference is the sign.
Both has the exact same structure but differs in the sign.
