What is the Equivalent Resistance between Points A and B?
The discussion revolves around finding the equivalent resistance between two points in a circuit, specifically points A and B, involving various resistors and their configurations.
  • Participants discuss the configurations of resistors, including series and parallel arrangements, and question the relationships between different resistors. Some participants attempt calculations for equivalent resistances based on their interpretations of the circuit.
The discussion is ongoing, with participants providing insights and questioning the arrangement of resistors. Some guidance has been offered regarding the series and parallel relationships, and suggestions to re-draw the circuit have been made to clarify the problem.
There appears to be some confusion regarding the series and parallel configurations of the resistors, particularly involving the 1, 2, and 10 ohm resistors. Participants are encouraged to show their work for better guidance.
tmr0116
Find the equivalent resistance between points a and b in the figure
1/Req = 1/R1+1/R2... for parallel
Req= R1+R2... for series
12.63 ohms
12.63 ohms
If you show your work, we can spot your errors and guide you. Or are you just asking if your answer is right?
I have that the 4 and 2 ohm resistor are in series and add to be 6 ohms equivalent resistor. The 6 ohm resistor and the 3 ohm resistor are parallel and 1/6+1/3=1/2 or 2 ohms equivalent. I don't know what to do next though. Are the 1, 2, and 10 ohm resistors in series?
No. If two elements are in series, all the current that goes through one has to go through the other. A current flowing through the 10-ohm resistor can go through the 9-ohm resistor or the 2-ohm resistor, so the 10-ohm resistor and the 2-ohm resistor are not in series. In contrast, all of the current in the 2-ohm resistor must also go through the 1-ohm resistor, so those resistors are in series.
Try re-drawing the circuit with your new values ... it may become clearer that way. Sometimes, it helps to re-draw the circuit vertically: in your case with "a" at the top of the diagram and "b" at the bottom.
  • · Replies 27 ·
  • · Replies 19 ·
