What is the fastest way to remove all water content from steam?
  • Context: Graduate
  • Thread starter Thread starter mark_d
    Steam Water
The discussion revolves around methods for efficiently removing water content from steam in a system designed to turn a turbine or generator. Participants explore various approaches and clarify terminology related to steam and air, while addressing safety concerns associated with the setup.
  • One participant seeks the fastest method to remove water from steam without significantly reducing air velocity.
  • Another participant expresses confusion about the terminology, emphasizing that there is only steam and no air in the system.
  • It is suggested that cooling the steam will cause condensation on the tubing, raising questions about pressure maintenance.
  • Participants propose two methods for water removal: sloping the pipe back to the tank or using steam traps at low points.
  • A participant mentions the need for a dry environment for the turbine and discusses the implications of water resistance on the generator.
  • There is a query about the difference between superheated air with 100% humidity and steam, with a suggestion that superheated air is not a valid concept.
  • Concerns are raised about the safety of the proposed setup, particularly regarding the use of a cast-iron BBQ pit as a pressure vessel.
Participants generally agree on the need to clarify terminology and safety concerns, but multiple competing views remain regarding the best method for removing water from steam and the definitions of steam-related concepts.
Participants highlight the potential dangers of the proposed steam system, particularly regarding pressure management and vessel integrity. There are unresolved questions about the definitions and properties of steam and humidity in the context of the discussion.
mark_d
I have a tank of water of boiling water and a small tube at the top. The output is to turn a turbine or generator, but I want to remove the water soon after it leaves the tank. That way I won't need to bother with condensation/water return later. What is the fastest way to remove the water content of the steam with minimal reduction of the air velocity?
I'm a little confused, but will take a shot: there is no air, only steam so you can't remove it from itself.
If you meant something different, please rephrase...
as you cool down the steam, it will condensate on the sides of the tubing; there will still be pressure on the end of the capillary tubing, though. Something has to cause the pressure, doesn't it?
[edit] Ok, I misread since you're mixing some terms together -- there is no air here, just steam...
You're saying that as steam leaves the tank, some will condense to water before gettting to the turbine. Certainly. There's two ways to remove it: Sloping and steam traps. Slope the pipe back to the tank and the water will run back on its own. If that's not feasbile, you'll need traps at the low points.
But let's back up: since you're a novice at steam power production, what are you using for a vessel and how much are you pressurizing it? This is potentially extremely dangerous and we need to deal with that issue if we are going to help you with the project.
I want the steam to pass over a squirrel cage and turn a generator. The squirrel cage will have the water resistance of the water collecting on it (over time) unless I do something about that and I also have to design a water return afterwards. The easiest way to have dry air passing over the wheel.
Sorry, I edited my post late after rereading yours...so please reread mine. But also, it would be helpful if you stop using the word "air"...
ok. no air. The heat will be provided by a wood-burning fire-box and the vessel will be a cast-iron bbq pit. relief valve to keep it under 80psi. sloping is the preferred design. trying to keep it simple.
what is the difference between superheated air with 100% humidity and steam?
If you remove the heat from steam in a closed system, what is left- water and a vacuum?
There is no such thing as "superheated air". If a steam system starts with air in it, typically the air is purged to avoid doing useless work moving the air around.
If the system is open, the steam will drive the air out.
Water and water vapor in a partial vacuum. You can check a steam table for the exact properties of the mixture.
mark_d said:
The heat will be provided by a wood-burning fire-box and will be a cast-iron bbq pit. relief valve to keep it under 80psi. sloping is the preferred design. trying to keep it simple.
I'm sorry, but that's not a legitimate pressure vessel and we can't support dangerous activities here.
  • · Replies 28 ·
