What is the Final Angular Velocity of a Cylinder?
The final angular velocity of a solid cylinder with a radius of 20 cm and mass of 20 kg, when a force of 100 N is applied to a massless rope wrapped around it, is calculated to be 18.4 rad/s. The torque generated is 20 Nm, and the moment of inertia is 0.4 kg m². The relationship between linear and angular motion is crucial, as the cylinder rolls without slipping, necessitating the use of both rotational and linear equations. The work-energy principle is also applicable in this scenario, providing an alternative method to arrive at the correct answer.
  • Understanding of torque and its calculation (T = F.R)
  • Knowledge of moment of inertia for solid cylinders (I = MR²/2)
  • Familiarity with angular momentum and its relationship to torque (L = Iω)
  • Concept of rolling motion and the rolling constraint (v = rω)
  • Study the work-energy theorem in rotational dynamics
  • Learn about the relationship between linear and angular motion in rolling objects
  • Explore examples of torque calculations in various physical systems
  • Investigate the applications of the moment of inertia in different shapes and bodies
Students studying physics, particularly those focusing on dynamics and rotational motion, as well as educators looking for practical examples of angular velocity calculations.
James50
I've got a synoptic paper coming up and for the life in me I can't remember how to do some basic dynamics!
A massless rope is wrapped several times around a solid cylinder of radius R = 20 cm, and mass M = 20 kg, which is at rest on a horizontal surface. Someone pulls 1 m or the rope with a constant force of 100 N, setting the cylinder in motion. Assuming that the rope neither stretches nor slips, and that the cylinder rolls without slipping, what is the final angular velocity of the cylinder of mass M and radius R. The moment of inertia of the cylinder is MR2/2.
T = F.R
L = Iw
T = dL/dt
T is torque, F force, R radius, I moment of inertia, W angular speed, L angular momentum, Y is the angle
Torque is 100x0.2 = 20 Nm. Moment of inertia is 0.4 kg m2. Now rearranging torque as a function of angular momentum, you get T = I dw/dt.
Some chain rule... dw/dt = w dw/dY. A little bit of integrating... 0.5 w2 = (T/I)Y -> using Y=0 as the lower boundary.
Okay, now because 1m is pulled from the rope, and the circumference of the cylinder is 1.256m, it works out that the sphere has rotated by 5 rads. Put that, along with T=20 and I=0.4 into the above equation, you come out with 22.36 rad /s. The actual answer is 18.4 rad /s. Ugh!
Welcome to PF!
Hi James50! Welcome to PF! :smile:
(have a theta: θ and an omega: ω :wink:)
eek!
You clearly need to do a lot of worked examples on rolling motion. :redface:
(btw, what's a synoptic paper? :confused:)
With rolling, you need two types of equation, one for rotational motion and one for linear motion …
you also need a rolling constraint (usually v = rω).
And in this case, since you're given distance (instead of time), mightn't a work energy equation save you … erm … both work and energy? :wink:
Thanks! I saw some symbols hanging around in the latex reference things but then it messed up all my paragraphing!
You're telling me! Nuclear physics and baryon decuplets I can do... But rotating bodies!
A synoptic paper is a general one, it lasts for something like 4 hours and has questions on all the modules in my degree (I've done over 30, ugh!)
I can't believe I didn't think of doing it that way. Got the right answer straight away, thanks! Although I still can't figure out the normal way of getting there!
hmm … I think I'd call that panoptic :wink:
Do F = ma and τ = Iω.
Do a forum search for "rolling" to find some other examples to work through. :smile:
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 17 ·
