What is the flow through pipe in an open channel?
The discussion focuses on calculating flow velocity through a pipe with varying diameters situated in an open canal. The water velocity is established at 3 m/s, with a water depth of 1.5 m. The inlet diameter is 0.9 m, the reduced diameter is 0.6 m, and the outlet diameter is 0.8 m. The flow is characterized as turbulent, and the nozzle is positioned at the center and bottom of the canal, affecting the overall velocity profile.
  • Fluid dynamics principles, specifically Bernoulli's equation
  • Understanding of turbulent flow characteristics
  • Knowledge of flow continuity equations
  • Basic hydraulic engineering concepts
  • Study Bernoulli's equation for energy balance in fluid flow
  • Learn about the continuity equation for varying cross-sectional areas
  • Research turbulent flow characteristics and their impact on velocity profiles
  • Explore computational fluid dynamics (CFD) tools for simulating flow in open channels
Engineers, hydrologists, and students studying fluid mechanics or hydraulic engineering, particularly those interested in open channel flow and pipe dynamics.
shafqut
I know this is easy but i need to know the flow velocity through a pipe reducing in diameter inside a canal.
the
water velocity is 3m/s
water depth is 1.5 m
the pipe is at the bottom
inlet diameter 0.9m
small reduced diameter 0.6m
outlet diameter = 0.8m
note: this is an open canal with velocity 3m/s
canal width is 6.096 m
At least tell me how this should be approached
Please provide more information regarding the location of nozzle wrt canal and how is the flow characteristics(laminar or turbulant)?
And as the nozzle is on open canal this property will also affect the flow velocity:
Though it is for pipe flow it will also affect canal flow so the velocity profile will not be linear.
Flow is turbulent..
the nozzle is at the center and at the bottom.
please mention any assumption you are taking .. can this be done using energy balance ?
  • · Replies 31 ·
