What Is the Interval of Convergence for the Series Summation?
hpayandah
Find the interval of convergence of each of the following
Ʃ^{∞}_{n=0} (\frac{3^{n}-2^{2}}{2^{2n}}(x-1)^{n})
Please refer to attachment
Please refer to attachment. All I want to know is that I'm doing this problem right. I have found the interval but haven't plugged the interval back into the equation.
You shouldn't break it into two series like that unless you know what you are doing. And combining them into (3/4)(x-1)-(1/4)(x-1) shows you probably don't. Just apply the ratio test to the whole expression.
The thing is I don't know what to do with that 2^2 in the equation, it throws me off. I'll re-post a picture this time everything together.
One of the factors in your ratio test should be (3^(n+1)-2^2)/(3^n-2^2), right? To find the limit of that as n->infinity, just divide numerator and denominator by 3^n.
I tried your suggestion, however I didn't come to a good end (maybe I did something wrong). Please take a look at the attached file; this is my re-attempt.
It looks more complicated than necessary- it should be obvious that
\frac{3^{n+1}- 4}{3^n- 4}
is dominated by 3^{n+1}{3^n}= 3 and so its limit is 3. But your result, that the limit is (3/4)|x- 1| is correct. Now, what is the answer to your original question?
Not right. There's a mistake in the long division. 3^(n+1)-3^n isn't 3. And I didn't mean that in my suggestion. Take (3^(n+1)-4)/(3^n-4). Dividing the numerator, 3^(n+1)-4 by 3^n gives you 3^(n+1)/3^n-4/3^n. What's 3^(n+1)/3^n? Now take the limit as n->infinity. Do the same with the denominator.
Thank you I got it now.
3n+1−43n−4
is dominated by 3n+13n=3 and so its limit is 3. But your result, that the limit is (3/4)|x−1| is correct. Now, what is the answer to your original question?
Thanks
