ahmed11
- 83
if i connect an electric current of 30 volts to argon gas to transform it to plasma, what is the average kinetic energy of the argon particles in that plasma?
The discussion centers on the generation of plasma from argon gas using electric current. A minimum arc voltage of 137 volts is required to create plasma, as 30 volts is insufficient. The kinetic energy of argon particles in plasma can be calculated as 30 eV per singly charged ion, equating to approximately 50 x 10-19 joules. Additionally, while plasma can exist at high pressures, such as 10,000 psi, it requires extreme temperatures that may compromise the integrity of the container.
PREREQUISITESPhysicists, electrical engineers, and hobbyists interested in plasma generation and its applications in various fields such as materials science and energy production.
[PLAIN]https://en.wikipedia.org/wiki/Paschen's_law said:For[/PLAIN] argon, the minimum arc voltage is 137 V at a larger 12 µm.
then how to make plasma with argon gas, i saw a couple of videos on the internet. could you please explain to me how this happens and how to do it?anorlunda said:Current is not measured in volts.
30 volts is not enough.Creating a gap of only 12 µm is not easy. You also need a vacuum.
The energy of the particles in the plasma depends on the distance from the arc. Energy considerations are also discussed in https://en.wikipedia.org/wiki/Paschen's_law
You could do a much better job in phrasing your question. The usefulness of answers here is proportional to the quality of the question.
It can exist, but only at completely unreasonable temperatures (evaporating the container walls).ahmed11 said:and also can a container of argon gas at 10,000 psi be converted to plasma with electricity or plasma can't exist at high pressure? assuming the container can hold it and how much electricity should be applied to convert that much argon to plasma if possible?
i just couldn't understand why only plasmas exist in low pressure gases and why can't they be applied to a higher situation, i thought that plasma have limitation with pressure of the gas and the voltage passing through it but thanks to you i get it nowmfb said:In general: a higher voltage can work.
Don't ask x-y questions please.
What do you actually want to do? Why do you want a high-pressure argon plasma?
