What Is the Magnetic Field at the Axis of a Circular Loop?
The discussion revolves around calculating the magnetic field at a specific point along the axis of a circular loop carrying a steady current. The loop is described as having a radius of 0.1 m and a current of 2.0 A flowing in a counter-clockwise direction. Participants are examining the magnetic field strength and direction at the observation point located at (0, 0, 0.1 m).
  • Participants discuss the application of Ampere's Law and express uncertainty regarding the path and angle involved in the calculation. Others suggest using the Biot-Savart Law, questioning how the magnetic field circulates at the observation point and the effect of horizontal components of the magnetic field from the loop.
The discussion is ongoing, with participants exploring different approaches to the problem. Some guidance has been offered regarding the use of the Biot-Savart Law, and questions about the contributions of various components of the magnetic field are being raised.
Participants note the presence of angles in the problem setup, which may affect the calculations. There is also a reference to specific sections of external resources that may provide additional context.
syhpui2
As shown in the figure below, a circular loop of radius a = 0.1 m lies in the horizontal x-y plane with its center located at the origin, with steady current I = 2.0 A circulating in a counter-clockwise direction in the loop. The magnetic field strength B(0,0,z) at the observation point (x, y, z) = (0, 0, 0.1 m) and its direction, due to the current I flowing in the circular loop is:
(a) B(0,0,z=0.1m) = 0.628 × 10-7 T, -z direction
(b) B(0,0,z=0.1m) = 2.323 × 10-6 T, +z direction
(c) B(0,0,z=0.1m) = 3.678 × 10-6 T, -z direction
(d) B(0,0,z=0.1m) = 4.443 × 10-6 T, +z direction
Answer is D
http://i.imgur.com/i6Zxf.png
Ampere's Law
I tried Ampere's law, but I am not sure what is B dot dl (especially angle) and what is the path in this case...
Thx
I believe you want the Biot-Savart Law, since we are dealing with a current loop, rather than a current-carrying straight wire.
At any point on the loop, which way does the magnetic field circulate? At the observation point, what is going to happen to the "horizontal components" (the parts parallel to the xy-plane) of all the bits of magnetic field coming from the loop? What will that mean as far as how the bits of magnetic field add up at ( 0, 0, 0.1 m.)?
Up, by RHR
Bcos(45)?
integral Bcos(45)dl?
syhpui2 said:
Thanks. But there is an angle in this case...
If you scroll down the page you arrive at the title "Magnetic field on the axis".
ehild
ehild
Okay. Thanks
  • · Replies 37 ·
9K
