What is the magnitude of the average force that the air bag exerts on the driver?
The problem involves a car crash scenario where a driver, not wearing a seatbelt, is slowed to a stop by an airbag. The context includes the mass of the car, the speed at impact, and the time taken to stop, focusing on calculating the average force exerted by the airbag on the driver.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the impulse-momentum theorem and its application to the problem. There are questions about the appropriate equations to use and how to set them up correctly. Some participants express confusion about the correct mass to consider in the calculations.
Several participants have attempted to set up equations based on the impulse-momentum relationship. There is an ongoing exploration of the correct approach, with some participants suggesting different interpretations of the problem and questioning the assumptions made in their calculations.
There is a side note regarding the implications of the average force exceeding a certain threshold and its potential lethality. Participants are also considering the distinction between the total mass of the car and the mass of the driver when calculating the force.
squintyeyes
A 1900 kg car moving at 20.0 m/s crashes into a brick wall and is stopped. The driver's mass is 70.0 kg, and although the driver is not wearing his seatbelt, the air bag thankfully slows him to a stop in 0.100 s. What is the magnitude of the average force that the air bag exerts on the driver?
______________
(Side Note: Air bags and seat belts act to slow you to a rest in a longer time. By increasing the time, the force on your body decreases. An average force exceeding roughly 2.00 x 105 N will probably kill you.)
How would you do this problem?
______________
Have you done impulse and change in momentum? The driver has an impulse supplied by the air bag that causes him to change momentum.
so what would the equation look like? how would you solve it?
Have you studied F*t...?
So i read up on this and did this. It was marked wrong can someone help me figure out why?
m*v = f*t
(1900 + 70)(20) = F * (0.1)
39400= 0.1F
F=394000
m*v = f*t
39400= 0.1F
F=394000
I believe they were asking about the force on the driver (70 kg) and he was moving at 20 m/s and then 0 m/s (stopped). So the driver's change in momentum is due to a force acting over a 0.1 second time period.
so would it be like this then?
m*v = f*t
(70)(20) = F * (0.1)
1400= 0.1F
F=14000
m*v = f*t
1400= 0.1F
F=14000
yeps...
I am assuming on the left hand side of your equation you had final momentum being zero. So really you end up with a force that is (-). Which basically means the driver was accelerated in the opposite direction as his initial motion.
9K
9K
