K.J.Healey,
K.J.Healey said:
How about : A parameter of the space in question
I would say yes, you are correct, relatively. I would accept that as a starting point.
So we are looking at a one dimensional length. What is the parameter? Is the parameter the dimension of length?
What does parameter mean in relation to this one dimensional length? Could parameter here mean a quantity that defines certain relatively constant characteristic of the system?
If that is the case, then does it really fit the meaning of dimension as it is used in the phrase “one dimensional length”?
Does not quiet fit to me. This definition of dimension seems more appropriate for what dimension means in the phrase “the dimension of the line segment is …”.
Considering that, it does make it more confusing if you are thinking of this meaning of dimension as opposed to the meaning of dimension as it relates to the phrase “one dimensional length”.
I’ve been so focused on the meaning of dimension and trying to explain it that I overlooked the idea that you could be thinking of the other meaning for dimension. The two definitions are very similar and yet not the same.
I should have thought about that confusion, my mistake there.
Now I understand better Matt Grimes comment about calling dimensions “units” instead of dimensions, if he is thinking about dimension as being a quantity measured, like the dimension of a line segment.
Apply your definition to a one dimensional length and see if that really works for defining the meaning of dimension as it is used here.
A one dimensional length.
A one parameter length.
A single quantity that defines certain relatively constant characteristic.
Can you explain better how this definition applies to dimension as used in the phrase “one dimensional length”?
Can you understand how my definition of dimension applies to dimension as used in the phrase “one dimensional length”? Have you tried to work it out?
My definition of dimension will not allow what Matt Grimes suggests.
In the definition of dimension that I am using, the definition I say applies to dimension as it is used in the phrase “one dimensional length”:
- Dimension does NOT equal a quantity.
- Dimension does NOT equal a unit.
- Dimension does NOT equal a unit of quantity.
Dimension as it is used in the phrase “one dimensional length” means:
A dependence of a given quantity on the base quantities of a system of quantities, represented by the product of powers of factors corresponding to the base quantities.
So what does this mean with relationship to the phrase “one dimensional length”?
Well, you can arbitrarily begin with any quantity of length of this “one dimensional length”. Let’s say we have X quantity the base quantities.
To measure that quantity you define some base quantity of length of this “one dimensional length”. Let’s say we define a base quantity called a “hand of length”, like when measuring how tall a horse is.
The system of quantities is simple, because we have only one dimension, so the system is the system of quantities of the “one dimensional length”.
The representation by the product of the powers of the factors corresponding to the base quantities is also simply, simply being “hand of length”^1.
- The X quantity of “hands of length” exists in the dimension of the “one dimensional length”
- The base quantity of “hand of length” exists in the dimension of the “one dimensional length”
- You can not add dimension as it is meant in “one dimensional length”.
- You can not measure dimension as it is meant in “one dimensional length”.
- You can add quantities of length that exist within the dimension of the “one dimensional length”.
It all holds together defining what dimension means when using the phrase “one dimensional length”.
Have you tried to work out the understanding of the definition I gave?
