What is the minimum force needed to make a wheel climb a step?
  • Thread starter Thread starter Carpe Mori
    Force Wheel
To determine the minimum force needed for a wheel of mass M and radius R to climb a step of height h, where h is less than R, the torque created by the applied force F at the axle must equal the torque due to the weight of the wheel. The solution involves analyzing the torques about the pivot point where the wheel contacts the step. The critical moment occurs when the torque due to gravity is equal to the torque from the applied force, which is when the required force F is at its maximum. The angle of the force relative to the pivot changes, but the focus remains on the point where the force must overcome the gravitational torque. Understanding these torque relationships is essential to finding the minimum force required for the wheel to ascend the step.
Carpe Mori
a wheel of mass M has a radius R It is standing vertically on the floor and we want to exert a horizontal force F at its axle so that it will climb a step against which it rests. The step has a height h where h<R what is the minimum force F needed?
torque = Ia
torque = FR
Alrighty so i know that to solve this problem i will have to set the torque created by F equal to torque created by the weight of the wheel (Tf = Tw) and then solve for F but i honestly have no idea how to do this. There was another topic created for this problem but i could not follow what they did =\
https://www.physicsforums.com/showthread.php?t=30938
help please?
There are only two forces to worry about: Find torques about the pivot point (where the wheel touches the step).
Start by drawing a diagram showing the forces and which way they act.
http://i35.photobucket.com/albums/d185/giddyrayne/Picture018.jpg
I understand torque = perpendicular force * radius
but it seems to me that the force's angle to the pivot point keeps changing.
True, but so what? You're asked to find the minimum force that would get it over the step. (At what point is the required force greatest?)
When the torque due to gravity is not greater than the torque due to the force...or i guess the force just has to be equal to it sooo when Tf=Tw?
At any point, in order to just get the wheel over the step Tf=Tw. The required force will be greatest initially, since that's the point where Tw is greatest. That's all you need to consider to find the minimum force.
