What is the minimum force needed to move a block with friction present?
The discussion revolves around determining the minimum force required to move a block in the presence of friction. Participants are exploring the implications of friction and normal force in this context, questioning the assumptions made about the direction of the applied force.
  • Participants discuss the relationship between applied force, friction, and normal force, with some suggesting that the minimum force is related to the coefficient of friction and weight. Others question the necessity of considering the angle of the applied force and how it affects the normal force and friction.
The discussion is active, with various interpretations being explored regarding the direction of the applied force. Some participants have provided insights into how applying force at an angle could lower the normal force, thus affecting the frictional force required to move the block. There is no explicit consensus, but productive questions and clarifications are being raised.
Participants note that the original problem statement did not specify the direction of the applied force, leading to confusion about whether it should be horizontal or at an angle. This lack of clarity is influencing the discussion on how to approach the problem.
  • #31
rudransh verma said:
Are you saying applying a force at an angle can decrease the friction without actually lifting it. That there is some ##0<F_N<mg##
You should be able to figure out the answer to this. What does force and torque balance on the block tell you? For simplicity, consider a homogeneous block with mass ##m## with a vertical string being pulled up attached to one of its sides. Will the block start tilting at the first minimal application of force? If not, how hard can you pull before it does?
  • #32
No. I think if we apply some upward force block will not move because ##F_N+ F_a=mg##. We need to increase the ##F_a=mg##. Then block will move. So we can apply a force to decrease the normal without actually lifting it up.
##F_a## is applied force.
  • Skeptical
  • #33
Not be lifted up, when does it start tilting? Did you draw a free body diagram and do the torque analysis?
  • #34
I have not studied about torque. Sorry. It’s in future chapters.
But I get it. Force at an angle will have its component in the direction of normal and that will decrease the normal force and thus friction. It will be enough to move the block forward.
  • #35
That is fine. Just as long as you are aware that until you reach and have learned those chapters, you will not really be able to tell when things tip over etc.
  • #36
Now that OP has announced that he "gets it", I think it is time for me to note that this question is not very well designed. Presumably it tests the extent to which the solver has mastered static friction and FBDs. However, its presentation as a multiple choice question leaves something to be desired because the entire process of finding the minimum force through an FBD, an understanding of ##f_s^{\text{max}}## and optimization, can be bypassed by a "solver" who knows nothing about these subjects but can interpret mathematical equations.
When ##\mu>1##, the first 3 choices are clearly greater than the weight ##mg##. In that case, one can "make the body move" by pulling straight up with a force that is equal to the weight and less than any of the first 3 choices. Thus, none of these can be a minimum. This leaves the fourth choice as the answer.
  • #37
Depending on the block dimensions, it might not be possible to move the block with minimum force so applied without its tilting.
Just as we are free to choose the angle of the force, we can choose where to a
apply it. By exerting it along a line passing through the point at floor level directly below the mass centre we can avert any risk of tilting.
Not that tilting is necessarily a disadvantage. If it turns out that it can allow a yet lower force magnitude then the problem is not well posed.
Specifying a rectangular block of given dimensions and a string attached to the base (say) at one end could be the basis of a more advanced question.
  • #39
If we think about it when we rather apply force at an angle we do decrease the force of friction but we now are applying some force against gravity. So are we really minimising any applied force?
Is friction playing bigger role than gravity?
  • #40
The entire point of this problem is to figure this out and to figure out which angle of application gives you the minimal force requirement.
  • #41
Right! So we make some eqns and find ##dF/d\theta## ie rate of change of force with respect to angle change and then take the derivative equal to zero to get the minima/maxima force.
So, ##dF/d\theta=0##, ##\mu =\tan \theta##
But how do you decide if its maxima or minima force at ##\mu =\tan \theta##?
  • #42
Do not just show your answers. Show your work. That would make it easier to suggest the second derivative test.
  • #43
$$F\sin \theta +F_N-mg=0$$
$$F\cos \theta- \mu mg=0$$
So,$$F=\frac{\mu mg}{\cos \theta+\mu \sin \theta}$$
Finding max/min force, $$dF/d\theta=0$$
After solving,
$$\mu=\tan \theta$$
  • #44
After solving,
$$\mu=\tan \theta$$
You have not shown your work taking the derivative of F and solving for the zero(es) of the resulting function.
  • #45
$$dF/d\theta=d/d\theta(\frac{\mu mg}{\cos \theta+\mu \sin \theta})$$
$$=-\frac{\mu mg}{(\cos \theta+\mu \sin \theta)^2}d/d\theta (\cos \theta+\mu \sin \theta)$$
$$=-\frac{\mu mg}{(\cos \theta+\mu \sin \theta)^2}(-\sin \theta+\mu \cos \theta)=0$$
$$=\mu mg\sin \theta-\mu ^2 mg\cos \theta=0$$
$$=\sin \theta-\mu \cos \theta=0$$
$$\mu=\tan \theta$$
  • #46
After solving,
$$\mu=\tan \theta$$
Your second equation seems to have assumed that the frictional force is ##\mu mg##, but this is no longer the case if the normal force is not ##mg##. It would imply ##F = \mu mg/\sin\theta##, but this is not what you obtain. Please show your intermediate steps.
  • #47
Orodruin said:
Your second equation seems to have assumed that the frictional force is μmg, but this is no longer the case if the normal force is not mg. It would imply F=μmg/sin⁡θ, but this is not what you obtain. Please show your intermediate steps.
Sorry, I did a blunder. Second eqn should be ##F\cos \theta-\mu F_N=0##. This should produce the correct eqn.
  • #48
In order to find whether it is a max or a min you need to take the second derivative of ##F## and find if it is positive or negative for the value of ##\theta## that you found. However, since the dependence on ##\theta## is in the denominator, it is probably easier to consider ##f = 1/F## instead. Since ##1/x## is a monotonously decreasing function (for ##x > 0##), ##f## and ##F## will share their extreme points. Where ##F## has a max, ##f## has a min and vice versa.
  • #49
First I started taking the usual case ##d^2F/d\theta^2=-mg\sin \theta(\cos^2 \theta(3\cos ^2 \theta-2)-\sin^2\theta(1+cos^2 \theta))##.
But its difficult to tell its -ve or +ve.
So as you said ##df/d\theta=(1/\mu mg)(-\sin \theta+\mu \cos \theta)##
and second derivative is ##-1/mg\sin \theta## after taking ##\mu =\tan \theta##
So its -ve. That means what?
Can you explain the maths in more detail here?
  • #50
Yes, that quickly becomes messy, which is why I suggested checking whether the denominator had a minimum or maximum since the numerator is constant. Those are tricks that one picks up with experience. Now the reason it works is the following, consider two (non-zero) functions ##F(x)## and ##f(x) = 1/F(x)##. We then have (##x## being some arbitrary variable the functions depend on)
f' = \frac{df}{dx} = \frac{d(1/F)}{dx} = -\frac {F'}{F^2}
and so ##f'(x_0) = 0## if ##F'(x_0) = 0##. It then also follows that
f'' = -\frac{d}{dx}\frac{F'}{F^2} = - \frac{F''}{F^2} + 2\frac{F'^2}{F^3}.
If we evaluate this for the extreme point ##x_0##, then ##F'(x_0) = 0## and therefore
f''(x_0) = -\frac{F''(x_0)}{F(x_0)^2}.
Hence, ##f''(x_0)## is positive if ##F''(x_0)## is negative and vice versa. So if ##x_0## is a max of ##f##, it is a min of ##F##, etc.
  • #51
You can easily verify this for yourself. Place a bathroom scale on the floor next to a table. Stand on the scale and it reads ##mg##. Place your hand on the table top and push down. The reading on the scale will now be less than ##mg##.
  • #52
kuruman said:
When μ>1, the first 3 choices are clearly greater than the weight mg. In that case, one can "make the body move" by pulling straight up with a force that is equal to the weight and less than any of the first 3 choices. Thus, none of these can be a minimum. This leaves the fourth choice as the answer.
Do you really think that a student who doesn't understand static friction and FBD's could carry out a line of reasoning like this? It's possible, but in my experience quite rare.
  • #53
F= m(a+g*Mus)/(cos(theta)-Mus*sin(theta))
You will have to find acceleration a from 1D motion with constant acceleration. Or if you're computer literate then simple numerical computation will do the trick. As to answering the question, the value of F has to be larger than the expression above.
  • #54
Edit: you can find a from a= ((v^2)-(x-xnot)/2)^1/2 expression.
  • #55
Let me type set that for you. It hurts my eyes otherwise.
##F=\frac{m(a+\mu_s g)}{\cos \theta - \mu_s \sin \theta}##
However, it still smells like gibberish to me.
My best guess at your formula for a is ##a=\sqrt{v^2 - \frac{x - \hat{x}}{2}}##
But what is ##a## in a problem that involves no acceleration? And what is ##x## or ##\hat{x}##?
  • #56
I assume you then got the equation ##F=\frac{mg}{\sin(\theta)+\mu\cos(\theta)}##.
When you see an expression like ##G=A\sin(\theta)+B\cos(\theta)##, theta being unknown, there is a trick that can be very useful. Let ##\tan(\alpha)=B/A##. So ##G/A=\sin(\theta)+\tan(\alpha)\cos(\theta)##
##(G/A)\cos(\alpha)=\sin(\theta)\cos(\alpha)+\sin(\alpha)\cos(\theta)=\sin(\theta+\alpha)##.
Notice that there is now only one occurrence of theta in the equation for G. It should be obvious what values of theta minimise or maximise G.
See if you can apply that here to avoid doing any calculus.
  • #57
Sorry I was using the formula for velocity from my memory. The actual acceleration formula is (v^2-v0^2)/2*(x-x0)=a
X0 is initial distance and v0 is initial velocity. With proper assumptions one can work out the math. And we need acceleration to overcome static friction. If this was dynamic friction, then my good Sir, your assumption would be correct.
  • #58
This seems to seriously miss the point of the exercise. Any motion will do to break static friction. Any non-zero acceleration, no matter how small, will suffice. The limit is clearly when ##a=0##. That is the limit that one must solve for. By Newton's second law, ##\sum F = ma##. With ##a=0## this occurs when ##\sum F = 0##. And we want static friction to be at its limit, so ##F_s = \mu F_n##. Easy peazy.
  • #59
This seems to be a confusion in me too. If we take a=0 we are calculating net force that will not make the body move. And we want to calculate minimum force required to move the block. There would not be even a slightest non noticeable acceleration.
And I said the same thing in previous post as you and yet you were skeptical. Why?
  • #60
This is like a problem in math where the minimum doesn't exist , but the infimum exists (the minimum acceleration or force doesn't exist for this problem but the infimum exists and it is zero(for acceleration)). Tell me if you are interested to hear more.
