What is the Next Number in this Series?
  • Thread starter Thread starter Aditya
The discussion centers around identifying the next number in a given series: 10, 4, 3, 11, 15. Participants explore various approaches to determine the next number, with a hint suggesting the solution is not math-related.
  • One participant suggests a pattern involving alternating increases and decreases in distance from a central number, proposing 14 as the answer.
  • Another participant argues that the reasoning is flawed, claiming the answer can be derived from the number of letters in the spelled-out numbers.
  • A different approach involves mathematical reasoning, where one participant sums pairs of numbers to arrive at a potential next number.
  • Multiple participants note that there are several independent rationales leading to the same answer of 14, but also mention other possible answers (1, 17, 12) based on polynomial fitting.
  • One participant asserts that the polynomial approach is not valid since the puzzle is not math-related, suggesting that the correct answer may not be among the provided options.
  • Some participants express skepticism about the validity of the patterns identified, emphasizing that a convincing solution should be simple and clearly intended.
Participants do not reach a consensus on the correct answer or the validity of the various approaches. Multiple competing views remain, with some supporting the answer of 14 while others question the reasoning behind it.
Participants highlight that the puzzle is intended to be non-mathematical, which complicates the use of polynomial fitting as a justification for the answers proposed.
Individuals interested in pattern recognition, logic puzzles, or non-traditional problem-solving approaches may find this discussion engaging.
Aditya
Which number is next in this series:
10, 4, 3, 11, 15...?
a. 14
b. 1
c. 17
d.12
Hint: Not Math Related
The pattern is this: number A, two numbers that are 1 in distance that decrease, one number 1 in distance from number A that increases, then two more numbers that are 1 in distance that decrease.
The answer is a, 14.
No, not really. Although the answer is correct, the reasoning behind it is incorrect. If you spell out each letter you can notice that for each number the number of letters increase by 1.
can it be 14?
lol..I got it in mathematical way. 10+11 = 21, 4+15 = 19 so 3+? = 17
Wow. Cool. 3 right answers, with 3 completely independent rationales for reaching it.
Correct answers are: a, b, c or d.
If I knew how to use lagrange to make polynomials to fit those points I'd prove it, too.
Its easier than that Alkatran:
The polynomial [itex]y = (x - 10)(x - 4)(x - 3)(x - 11)(x - 15)(x - 14)[/itex] has zeros 10, 4, 3, 11, 15, and 14. This justifies the answer a. 14.
The polynomial [itex]y = (x - 10)(x - 4)(x - 3)(x - 11)(x - 15)(x - 1)[/itex]has zeros 10, 4, 3, 11, 15, and 1. This justifies the answer b. 1.
The polynomial [itex]y = (x - 10)(x - 4)(x - 3)(x - 11)(x - 15)(x - 17)[/itex] has zeros 10, 4, 3, 11, 15, and 17. This justifies the answer c. 17.
The polynomial [itex]y = (x - 10)(x - 4)(x - 3)(x - 11)(x - 15)(x - 12)[/itex] has zeros 10, 4, 3, 11, 15, and 12. This justifies the answer d. 12.
However, the correct answer to the puzzle was not one of the choices. You see the polynomial [itex]y = (x - 10)(x - 4)(x - 3)(x - 11)(x - 15)(x - \pi)[/itex] has zeros 10, 4, 3, 11, 15, and [itex]\pi[/itex]. So there is no correct answer.
a. 14
b. 1
c. 17
d.12
This is the only one that makes sense to me.
Wow... It's amazing how many patterns and relationships you can find, and they are all valid. I got my answer the same way that z-component got his.
I don't think anybody has a convincing stab at this puzzle (myself included). Solving a pattern requires that you find something that is obviously right. Just being able to construct something that fits the pattern isn't enough. It has to also be simple and clearly the intended answer. Only if the intended answer does not itself fit those criteria is the pattern flawed.
Plus, aditya said this is NOT math-related. No polynomials allowed. That's not the real point of why the polynomial approach is not right, but it adds some extra irony.
I agree. Finding a pattern may not mean that you've found the answer. I think this one was a pretty creative pattern.
9K
  • · Replies 19 ·
