What Is the Non-Deformed Length of a Spring Between Two Linked Bodies?
  • Thread starter Thread starter inv4lid
    bodies Spring
The discussion focuses on determining the non-deformed length of a spring connecting two masses, m1 (1 kg) and m2 (4 kg), with observed lengths of 5 cm and 15 cm under different conditions. Participants suggest using Hooke's Law, represented as m1g = kx1, where k is the spring constant and x1 is the compression of the spring. The challenge lies in correctly defining the variables and equations to eliminate unknowns and solve for the spring's natural length.
  • Understanding of Hooke's Law and spring mechanics
  • Basic knowledge of forces and mass (Newton's laws)
  • Ability to manipulate algebraic equations
  • Familiarity with concepts of compression and deformation in springs
  • Study the derivation and application of Hooke's Law in various scenarios
  • Learn how to solve systems of equations with multiple unknowns
  • Explore the concept of spring constants and their determination through experiments
  • Investigate the effects of different masses on spring deformation
Students studying physics, particularly those focusing on mechanics and spring dynamics, as well as educators looking for practical examples of Hooke's Law in action.
inv4lid
two linked are attached to each other with a spring. If the second body is placed on a fixed support, the length of the spring is 5 cm. If we fix the first body as in the picture, the length of the spring becomes 15cm. Determine the length of the spring in the non-deformed state.
m1 = 1 kg;
m2 = 4kg;
l1 = 5cm;
l2 = 15cm;
This time i have really no idea. The m1 pushes the spring with a force of 10N and m2 should like respond with another force? Quite don't get it.
Any help would be greatly appreciated.
I suggest using Hooke's law.
10 N = kΔL?
ΔL1 = L1 - L0 from there
L0 = -ΔL1+L1 -> L0 = -ΔL1+5
ΔL2 = L2-L0 from there
L0 = -ΔL2+L2 -> L0 = -ΔL2+15
Quite still don't get it.
inv4lid said:
10 N = kΔL?
If we take the first case with the mass ##m_1##. Let ##L## be the natural length of the spring and ##x_1 > 0## be the contraction due to ##m_1##. Then, by Hooke's law:
##m_1g = kx_1##
Where ##k## is the (unknown) sprong constant.
Does that get you started?
##m_1g = kx_1##
What is x?
I assume it's a different writing form of ΔL? Ok.
Sorry, but i have already tried that above.
mg (which is 10N) = kx, where both k & x are unknown
inv4lid said:
What is x?
##x_1## is the distance that the spring is compressed from its natural length under the weight of ##m_1##.
inv4lid said:
What is x?
Yes, I forgot you had used ##\Delta L_1##.
It doesn't matter how many unknowns you have at this stage. The trick is keep going with the next equation and hope that you can get rid of the unknowns at some stage.
A question there: why do we need m2 there if it doesn't influence the object?
We don't. I think the premise is that they are joined together. The mass of ##m_2## doesn't affect the first scenario, nor does ##m_1## affect the second.
You might also ask how they managed to attach ##m_1## to the ceiling, but I wouldn't worry about that either.
Okay.
m1g = k(x1-x0)
m1g = k(x2-x0)
10 = k(5-x0)
10 = k(15-x0) that's though quite non-sense
inv4lid said:
Okay.
m1g = k(x0-x1)
m1g = k(x0-x2)
10 = k(x0-5)
10 = k(x0-15) that's though quite non-sense
In post #4 I had:
##m_1g = kx_1##
That seemed the simplest approach. My thinking was: the spring is being compressed by a certain amount. Let's call that ##x_1##.
But, if you are going to use:
##m_1g = k(x_0 - x_1)##
Then you have to be careful about what ##x_0## and ##x_1## are.
In your second equation things have gone wrong. You've still got ##10## for the force, which can't be right. And, you've got negative numbers creeping in.
Anyway, you need to fix those equations. We can stick with your notation, but you need to be careful about how you are defining things.
PeroK said:
In post #4 I had:
##m_1g = kx_1##
Then you have to be careful about what ##x_0## and ##x_1## are. ##x_1## can't be "5" here.
Okay. Ty for everything, going to solve it.
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 97 ·
9K
