What is the proof of the formula L1 +pL2=0?
  • Thread starter Thread starter 1/2"
    Formula Proof
The discussion centers on the proof of the formula L1 + pL2 = 0 for two intersecting lines L1 and L2, where L1 is defined as a1x + b1y + c1 = 0 and L2 as a2x + b2y + c2 = 0. It is established that any line passing through their intersection point P can be expressed in this form, as substituting P into the equation yields 0. The concept of a "family of lines" is clarified, indicating that varying the constant p results in different lines through point P. Participants express confusion over the proof's derivation and the implications of concurrent lines, particularly regarding the relationship between their equations. Ultimately, the proof hinges on the fact that if P satisfies both L1 and L2, it must also satisfy the combined equation, confirming its validity.
1/2"
This related to coordinate geometry.
According to my book it says if there are two intersecting lines L1(a1x+b1y+c1=0) and L2(a2x+b2y+c2=0)
Then equation of any line passing through their point of intersection is
L1 +p L2 =0
or (a1x+b1y+c1=0) +p(a2x+b2y+c2=0)=0
where p is some constant
my problem is that i don't understand what is the proof of this formula.Book also says that (a1x+b1y+c1=0) +p(a2x+b2y+c2=0)=0 represents a Family of lines , and i don't understand what it means too.
i tried to use some arbitrary line equations and tried to simultaneously solve the equations
and get its point of intersection and find the line's equation but i can't relate these 2 methods
If k is such that it a1-p.a2=0 how does this proove these lines are concurrent and it equation is (a1x+b1y+c1=0) +p(a2x+b2y+c2=0)=0
book gives the proof as since this line satisfies some P(a,b) hence when we put it into the equation it will yield 0
But that comes only after i have proved this is the equation of all lines passing through common point ,how can this be a proof?
Could you please give me a proof of how this formula is derived?
Thank you.
You have a line Lp defined by, (a1x+b1y+c1) +p(a2x+b2y+c2)=0. Say that lines L1, L2 intersect at a point P, then P is both on L1 and on L2, thus a1*Px+b1*Py+c1 = 0 and a2*Px+b2*Py+c2 = 0. 0+p*0 = 0 so P is also on Lp. That's all there is to it.
A family of lines means that Lp is not any specific line. It could represent many different lines, if different values of p are used.
I already know if P satisfies L1 and L2 it is on line L1 and L2 because basically equation of line L1 and L2 is a condition & when we graph it we get a line.But what i am asking is HOW DO WE KNOW EQUATION OF LINES PASSING THROUGH A POINT CAN BE GIVEN BY (a1x+b1y+c1=0) +p(a2x+b2y+c2=0)=0
I WANT THE PROOF .
One more thing i found was if we add or subtract the equations of two intersecting lines the resultant line will be concurrent to the other two lines
And if it is correct(which i hope it is(!):redface:) then how can find if they are concurrent from their equations when the slope and the y-intercept always remains the same no matter which point on line we take.
In the line equation ax + by + c = 0, (a, b) is a normal of the line. Another way to write the same equation is <(a, b), (x, y)> = -c, where < , > is the scalar product. It follows from properties of < , > that if <p, q> = w then if you take any vector n, orthogonal to p, <p, q+n> is also = w.
Or was that not what you were asking again?
What I gave you is a valid proof that if L1 and L2 both contain P, then so does L1+p*L2. It is not necessary to derive a thing to prove it.
I don't understand!
You'll have to be more specific. Do you know what a normal is? A scalar product? That <a, b> = 0 if a and b are perpendicular? That <a+b, c> = (ax+bx)*cx + (ay+by)*cy = ax*cx + ay*cy + bx*cx + by*cy = <a, c> + <b, c>?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
