What is the purpose of integration?
  • Context: High School
  • Thread starter Thread starter mrtn
    Integration
The discussion revolves around the purpose and applications of integration in various fields, particularly in physics and mathematics. Participants explore how integration relates to real-world scenarios, such as calculating work done and understanding motion, while also questioning the significance of the area under a curve.
  • One participant expresses confusion about the practical applications of integrals, questioning what the area under a curve signifies about a function.
  • Another participant provides examples of integration in physics, such as calculating work done and relating it to distance and power, emphasizing its importance in various fields.
  • A participant discusses how integration generalizes the distance-speed-time relationship for non-constant velocity, illustrating this with a breakdown of time into small increments.
  • There is a discussion about the units of work, with one participant confirming that work is measured in Joules, while noting that integration can yield different units depending on the context.
  • One participant presents a specific problem involving a braking car and attempts to integrate the velocity function, seeking clarification on the significance of the negative sign in their result.
  • Another participant points out that the negative sign should not appear in the final answer, suggesting a need for careful handling of signs in integration.
  • A later reply suggests that understanding the background of integration and Riemann Sums may provide further clarity on the topic.
Participants express various views on the significance and applications of integration, with some agreeing on its importance in physics while others remain uncertain about its implications. The discussion includes both supportive and questioning perspectives, indicating that no consensus has been reached on the broader significance of integration.
Participants highlight the need for clarity regarding units and the interpretation of results in integration, indicating that assumptions about context and definitions may influence understanding. There are also unresolved questions about the implications of negative results in specific integration problems.
mrtn
Right after learning integrals in my first calculus class, this past summer, I realized that they never told us how integrals are actually applied to the real world. Why would I want to know the area in an interval bounded by the curve and the x-axis? What does that say about the function?
Finding the derivative of a function allows you to calculate the rate of change at a point by finding the slope at such point. . . . Okay, I was going to attempt to answer my own question, but I'm totally blank.
Integration and Derivations are important in many different aspects. The first field is physics where the integral could mean the amount of work done, distance, power, etc. While in chemistry, NMR (a molecular technique to determine compounds) uses integrals to determine the number of hydrogens present at a specific signal. That's only to name a few.
There are so many applications that any list I could think of would be certain to be incomplete. So let me just pick one really common example from physics. We all know the simple distance-speed-time relationships, distance = speed x time for example.
Great formula but, it only works when speed is a constant! This is extremely limiting and means we can't handle any type problem involving accelerated motion. Fortunately calculus let us salvage that equation and make it much more general.
Say that we are trying to apply that equation, [itex]x = vt[/itex], (where "x" is distance), except the velocity "v" is not constant. Since the equation "dist = speed x time" only applies for constant velocity, it looks like we're stuck? Imagine however that we divide up time into lots of really small slices, say for example one microsecond increments*. Now over such a small time increment any changes in velocity will be very small so we can take "v" as approximately constant within any given time slice. That is, we can now use our formula despite the fact we have accelerated motion.
The new problem however, is that we are only finding the distance traveled one microsecond at a time, and we have to add up all of those one microsecond slices to find the total distance traveled. This is what integration does. We write the distance traveled in one time slice "dx" as,
[tex]dx = v \, dt[/tex]
Where "dt" is the small time slice and "dx" is the small distance traveled. This of course integrates to,
[tex]x = \int v \, dt[/tex]
So we've taken a simple speed time formula that only works for constant speed, and made it into a much more general integral equation that works for velocity as an arbitrary function of time. Physics and Engineering are absolutely full of applications very like this.
* The example of one microsecond is just to help you visualize it. Of course differentiation and integration are defined in terms of the limit as this time slice goes to zero.
uart, I think I get what you're saying, but I'm still not sure what the area under a curve says about the function itself. In general I mean. From what DmytriE said, I'm assuming you could tell the amount of work done of an accelerating car? What units is that measured in? Joules?
The work done is just a different example of the same thing, but don't mix up the two issues. If the force is constant then the equation is "Work = Force x Distance". But what if the force is not constant. This is just another example of exactly the same situation as I described above.
The equation [itex]W = F x[/itex] ("x" is distance) which is only true if "F" is a constant, becomes,
[tex]W = \int F \, dx[/tex]
Test yourself on an actual problem.
Q. A heavily braking car moves in a straight line with a velocity versus time given by [itex]v(t) = 36 - t^2[/itex] m/s, for t=0 to t=6 seconds.
How far does the car travel in the six seconds that it takes to stop?
First, yes the units for work is Joules. However, after integrating you can have different types of units. uart's example after integrating velocity (units: m/s) you get just (m). So integration is not strictly used for work problems. In general, integration is a simple way to find out the area under a non-linear function.
Example:
If f(x) = x^2. Integrating that without a boundaries gives you 1/3 x^3 + c. But with limits you are able to determine the area under the curve. That area under the curve corresponds to the amount of (something). That is all it represents.
Things to take away: the integral of a function does not mean anything unless the units are known.
I'm not sure if it's right. It looks weird. Here's what I did: first, I integrated the formula for the car that is breaking.
[itex]\int[/itex][itex]^{6}_{0}[/itex] 36-t2 dt
Then I used the fundamental theorem of calculus.
[36t-[itex]\frac{1}{3}[/itex]t3][itex]^{6}_{0}[/itex]
Which would be
-(36(6)-[itex]\frac{1}{3}[/itex](6)3)=-144
I'm barely into Calculus 2, so I'm not sure how to handle units. Would this mean that the car traveled 144 meters? Does the negative sign mean anything?
The car does travel 144 meters. However, there shouldn't be a negative sign in the answer or in front of the expression.
If you think about the background of integration and the Riemann Sums and how they are formed it would perhaps help...
  • · Replies 27 ·
  • · Replies 20 ·
  • · Replies 53 ·
