Finding the Sine of an Acute Angle Using the Pythagorean Theorem
  • Thread starter Philosophaie
In summary, the question is asking for the simplification of sin(acos(x)). This can be approached in two ways depending on the interpretation of "acos(x)". If "acos(x)" is the inverse cosine function, then the expression simplifies to sqrt(1-x^2). If "acos(x)" is a constant, then the expression cannot be simplified further. In order to find sin(acos(x)), we can use the definition of sine and the Pythagorean theorem to find the value of the expression.
Philosophaie
462
What is the sin(acos(X))?
Mathematics news on Phys.org
Is this a homework problem?
Also, by "acos" do you mean arccos, or inverse cosine, or is a a constant?
Is acos(x) the inverse cosine (arccos x), or is it [itex]a\cos x[/itex]? In the latter case, I don't think there's a particular simplification for the expression -- sine takes angles as arguments, and [itex]a\cos(x)[/itex] is not interpreted as an angle.
If you mean [itex]\sin(\arccos(x))[/itex], then x is an angle. Let [itex]\theta = \arccos(x)[/itex] so that [itex]x = \cos \theta[/itex]. We can draw a right-triangle containing the angle [itex]\theta[/itex] in the following manner: the side adjacent to [itex]\theta[/itex] has length x, and the hypotenuse has length 1. Then the third side (the side opposite [itex]\theta[/itex]) has length [itex]\sqrt{1 - x^2}[/itex]. Note that this is possible, since [itex]-1 \leq x \leq 1[/itex]. Also, [itex]{-\pi \over 2} \leq \theta \leq {\pi \over 2}[/itex] because of the restricted range of arccos, which enabled us to use the right-triangle as a diagram. Now, observing the triangle, [itex]\sin(\arccos x) = \sin \theta = \sqrt{1 - x^2}[/itex].
This problem is confusing. In the title, you have sin(Acos(x)), which implies to me that A is a constant. In the text of post #1 you have sin(acos(x)), which made me think you were asking about the arccos function. Which is it?
Take x to be the length of one leg in a right triangle having hypotenuse of length 1. "acos(x)" is the angle adjacent to x. Use the Pythagorean theorem to find the length of the other leg and then use the definition of sine to find sin(acos(x)).
Related to Finding the Sine of an Acute Angle Using the Pythagorean Theorem
What is the sin(Acos(x))?
The sin(Acos(x)) is a mathematical function that calculates the sine value of the inverse cosine of x. In other words, it finds the sine of the angle whose cosine is x.
Why is the sin(Acos(x)) important?
This function is important in trigonometry and geometry, as it allows us to find the missing side or angle in a right triangle when given the cosine value and one other side or angle.
What is the domain of the sin(Acos(x)) function?
The domain of this function is -1 ≤ x ≤ 1, as the cosine function can only have values between -1 and 1, and the inverse cosine function will give us an angle in radians.
What is the range of the sin(Acos(x)) function?
The range of this function is also -1 ≤ y ≤ 1, as the sine function can only have values between -1 and 1.
How do you calculate the sin(Acos(x))?
To calculate the sin(Acos(x)), you can follow these steps: 1) Use the inverse cosine function to find the angle A in radians. 2) Use the sine function to find the sine value of A. 3) Substitute the value of A into the function sin(Acos(x)).
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
