What is the Time Relationship of Alternating Current and Maximum Values?
The discussion revolves around a homework problem involving the time relationship of alternating current (AC) and its maximum values, specifically focusing on a 50 Hz AC waveform with a maximum current of 42.42 A. Participants explore how to determine the time at which the current reaches specific values, including 30 A and its maximum value, using mathematical relationships related to sine functions.
  • Homework-related
  • Some participants express concerns about the phrasing of the problem, suggesting that it lacks sufficient detail, such as a time unit for frequency.
  • Others propose interpreting the problem as involving a 50 Hz sine wave and suggest using the sine function to find the required times for specific current values.
  • There is a discussion on the correct application of the sine function, with participants debating the steps to isolate the variable and solve for time.
  • One participant calculates a time value of approximately 0.0025 seconds for when the current reaches 30 A, while another emphasizes the importance of significant figures in reporting the answer.
  • Participants discuss how to approach finding the time when the current reaches its maximum value, with references to the sine wave's properties and periodicity.
  • There is a mention of using graphical representations to aid understanding, with one participant sharing a link to a visual resource.
Participants do not reach a consensus on the phrasing of the problem or the exact method to solve it. There are competing interpretations of the problem and differing opinions on the correct approach to finding the time values.
Some assumptions about the problem's phrasing and the definitions of terms are not fully resolved. The discussion includes various interpretations of the sine function and its application to the problem, which may depend on participants' understanding of AC waveforms.
ineedhelpengr
A 50 cycle alternating current has a maximum value of 42.42A . It crosses the time axis in a positive direction when time is zero. Determine (a) the time when current first reach a value of 30 A. (b) time when current after having gone through its positive maximum value.
i don't think this problem is phrased well, making it unsolvable. for example, a frequency needs a time unit attached to it. "50 cycles" means nothing. Also, the function "crossing the time axis in a positive direction" does not seem like enough info to restrict the current's function to a single possibility.
I think he possibly means:
A 50Hz sin wave has 42.42A amplitude.
a) Show at what time the amplitude is 30A
b) Show at what time the amplitude is at its maximum
So translate that into Amplitude*sin(w*t) and solve for the required values.
That is right, except the question was in terms of currents.
so, you would say
30 amps = 42.42 amps * sin ( 2 * pi * F * t)
where F is the frequency in Hz and t is the time you need.
remembering to calculate the inverse sine in radians.
so would it be
sin-1(2*3.14*50*0)= 42.42 amps - 30 amps?
so would it be
No, take the 42.42 to the other side and you get 30 / 42.42 = sine of something.
So, you need to find the something. What angle (in radians) has a sine of 30 /42.42?
This what the sin^-1 function on your calculator is for.
So, you would take the inverse sine of 30 /42.42 then put (2 * 3.14159 * 50 * t) equal to that answer. Then solve for t.
The sine of anything has to be between +1 and -1. You can see that the ratio 30 / 42.42 is in this range.
Another check is that a 50 Hz sinewave has a period of 0.02 seconds (1 / 50) so a quarter cycle occurs in 0.02 / 4 seconds or 0.005 seconds. So, you must get an answer between zero and 0.005 seconds.
I got 0.0025004829... is that correct for t?
Yes, but you wouldn't quote it like that. The supplied data has only 4 significant figures, so you can't give an answer with 10 significant figures, even if your calculator produces them like that.
So 0.0025 seconds would be better.
These are very important, so try to get good at them. What would you do if the question asked for the current after 0.0015 seconds?
Got your PM, but I have answered it here so I won't repeat it in a PM.
Oh okay, thanks.
hmm.. for the second one... should the equation look like this..?
CURRENT = 42.42 amps * sin ( 2 * pi * F * 0.0015) ?
I am not sure on how to get the answer for B
Yes, that would be right.
I gave you a clue to B earlier:
When does a sinewave become a maximum value?
is it 1.414 rms?
I am confuse
Maybe this will help:
[PLAIN]http://dl.dropbox.com/u/4222062/sinewaves%202.PNG
[PLAIN]http://dl.dropbox.com/u/4222062/sinewaves%202.PNG[/QUOTE]
should t=.5 seconds?
Why?
You can use the same formula if you like:
42.42 = 42.42 * sin ( 2 * 3.14159 * 50 * t)
sin ( 2 * 3.14159 * 50 * t) = 1
( 2 * 3.14159 * 50 * t) = sin ^-1 (1) = 1.57079 radians
so t = 1.57079 / 314 = 0.005 seconds
But you can see this answer from the graphs above.
