What Is the Velocity of the Center of Mass of the Disk?
The discussion revolves around determining the velocity of the center of mass of a disk subjected to a pulling force, as well as calculating its rotational kinetic energy. The problem involves concepts from dynamics and rotational motion, specifically relating to a disk on a nearly frictionless surface.
  • Mixed
  • Participants explore the relationship between kinetic energy and work done on the disk, with one suggesting to equate work to kinetic energy to find the speed of the center of mass. Others discuss analyzing the system as both a point particle and a real system, considering translational and rotational kinetic energy.
Some participants have shared their attempts and reasoning, while others express confusion about the calculations involved. There is acknowledgment of mistakes in previous attempts, and a few participants indicate they have gained clarity on the problem after discussing it.
Participants mention specific values for mass, radius, force, and distances related to the disk's movement and string unwinding, which are critical to solving the problem. There is also a reference to class examples that may provide context for the discussion.
ohheytai
What is the speed of the center of mass of the disk?
A string is wrapped around a disk of mass m = 1.5 kg and radius R = 0.11 m. Starting from rest, you pull the string with a constant force F = 6 N along a nearly frictionless surface. At the instant when the center of the disk has moved a distance x = 0.10 m, a length d = 0.31 m of string has unwound off the disk.
(a) At this instant, what is the speed of the center of mass of the disk?
(b) At this instant, how much rotational kinetic energy does the disk have relative to its center of mass?
i know Krot is 1/2(I[tex]\omega[/tex]^2
but i have no clue how to do the first part
i know Vcm is Mass*v + mass*v2 +... over Total mass but yaa i don't know how to do this someone help!
I've got the same assignment due tonight.
For the first part, you can set Kinetic Energy equal to the work done on the disk, W=Fd. d is the distance the center of the disk moves. From there, just solve for v, so:
Fd = .5*m*v2
Were you able to get the second one?
For the second question, it's like the PRS example in class.
You have to analyze the system first as a point particle system, then as a real system.
SO:
PP-
delta E sys = W surr, pp
delta K trans = W surr = F (dot) delta r CM
delta K trans = Fx
Real -
delta E sys = W surr, real
delta K trans + delta K rot = F (x + d)
delta K rot = F(x + d) - Fx
since K rot, i = 0
K rot, f = Fd
I tried
Krot,f = F*d
where d is the distance the center of mass moves, but I got the incorrect answer, and it was my last try. Oh well, I must've used a wrong number. Thanks for your help though!
zalnas said:
I tried
Krot,f = F*d
d was actually supposed to be the length that the string unwound.
These questions are quite confusing. lol
Damn. That makes sense now that I think about.
Yeah. lol
At least you see how to do it now?
Yes I do. Thanks for your help.
  • · Replies 25 ·
  • · Replies 19 ·
