Why is the output different for this integral in Mathematica?
  • Thread starter Thread starter JulieK
    Integral
The integral discussed is \(\int\left(\frac{\mathrm{arcsinh}(ax)}{ax}\right)^{b}dx\), where \(a\) and \(b\) are constants. The substitution \(ax = \sinh t\) leads to a complex expression that Mathematica fails to simplify into standard mathematical functions, returning "no result found." The user reports a different output when using the command Integrate[((ArcSinh[a * x])/ a * x)^b, x] in Mathematica, which results in \(\[Integral]((x ArcSinh[a x])/a)^b \[DifferentialD]x\). This discrepancy arises from Mathematica's handling of symbolic integration and its inability to express the integral in simpler terms.
  • Understanding of integral calculus and substitution methods.
  • Familiarity with hyperbolic functions, specifically arcsinh and sinh.
  • Basic knowledge of Mathematica syntax and functions.
  • Experience with symbolic computation and limitations of integrators.
  • Explore advanced integration techniques in Mathematica, focusing on Integrate function options.
  • Study the properties and applications of hyperbolic functions in calculus.
  • Learn about symbolic computation limitations and how to interpret results in Mathematica.
  • Investigate alternative mathematical software for symbolic integration, such as Maple or MATLAB.
Mathematicians, students of calculus, and users of Mathematica who are interested in advanced integration techniques and the behavior of symbolic integrators.
JulieK
What is this integral
where a and b are constants.
The substitution ax = \sinh t yields <br /> \int \left(\frac{\mathrm{arcsinh}(ax)}{ax}\right)^b\,dx = \int \left(\frac{t}{\sinh t}\right)^b \frac{\cosh t}{a}\,dt \\ <br /> = \left[ \frac{1}{a(1-b)}\frac{t^b}{(\sinh t)^{b-1}}\right] <br /> + \frac{b}{a(b - 1)} \int \left(\frac{t}{\sinh t}\right)^{b-1}\,dt \\<br /> on integration by parts. Unfortunately that seems to be as far as one can get.
The wonderful Wolfram online integrator can't do it, so there's not much hope...
I confirm, Mathematica replies: "no result found in terms of standard mathematical functions" which is true in most cases.
Just starting with Mathematica, I type in:
Code:
and I get out:
Code:
Is there some reason I am getting a different output?
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 17 ·
