What Is This Object on the Titan Rocket?
- Thread starter Integral
- Start date
153 replies · 15K views · last reply
Danger
- 251
The entire centre section there is the injector assembly. Although I can't say for sure about this particular engine, the injector holes are generally machined in concentric circles. Ideally, alternating rings should feed propellant, and the ones between oxydizer. Since the components are equally reactive in liquid form, atomization is accomplished by the initial turbulence; any remaining droplets are quickly deconstructed by the combustion violence.brewnog said:what's being squirted where? And how come I don't see any GT style atomisers? Is it because there's no issue of getting everything to fully combust at those temperatures?
The picture that you posted is pretty dark, but it looks like cast iron to me. Must be something fairly old, like maybe a printing press.
- 8
Danger said:The entire centre section there is the injector assembly. Although I can't say for sure about this particular engine, the injector holes are generally machined in concentric circles. Ideally, alternating rings should feed propellant, and the ones between oxydizer. Since the components are equally reactive in liquid form, atomization is accomplished by the initial turbulence; any remaining droplets are quickly deconstructed by the combustion violence.
Okay, thanks for that!
It is cast iron.
It's pretty old, but it's a case of the broom which has had 3 new handles and 4 new heads, - the original will have been there a few hundred years before the existing one was installed. The original was first installed somewhere in the 1600's, although it would have been wooden back then. This one's probably around a hundred years old.
Danger
- 251
[/URL]brewnog said:Have a slightly bigger picture. There's a good clue if you look closeishly.
http://personalpages.umist.ac.uk/student/E.Smith-2/guess11.jpg
You beat me to it! I just took the liberty of tweaking it myself.
http://img173.echo.cx/img173/5493/guess103hu.jpg
Yours is better though, because of the expanded view. The only 'cluish' thing that I see is the boards bolted across. Maybe an old paddle-wheel in a mill?
- 8
Danger said:Yours is better though, because of the expanded view. The only 'cluish' thing that I see is the boards bolted across. Maybe an old paddle-wheel in a mill?
That was the clue indeed, and it is a paddle-wheel.
But not in a mill...!
Bed time now, I'll leave you to ponder this one overnight.
- 11
Not in a mill? Damn. That just ruled out 95% of my guesses. 1600's? Perhaps it's from a very old pump mechanism?
Danger
- 251
I'm lousy at history, so the time scale might be way off... early steamship?
zanazzi78
- 115
- 1
Does it power a loom?
- 8
Some more hints:
While it's not a mill or loom, it's not far off. Originating in the 1600s, it's water powered. It's not a pump mechanism, although a similar water-wheel is sited in the same building a few yards away which did power a pump, although a century or two later (while this one was still operational).
I believe it stopped working around 1900.
I'll tell you that it was in the North of England, not far from icvotria actually.
zanazzi78
- 115
- 1
Ok did it power bellowes in an iron foundry
zanazzi78
- 115
- 1
Is it situated in a Steel Foundry (since your from sheffield!)?
A grinding wheel, powered press or stamp?!
honestrosewater
- 6
Did it power a tilt hammer? Is it on the River Sheaf in Abbeydale?
honestrosewater
- 6
Ah, Top Forge!? It's from the other side, but this must be it: http://www.topforge.co.uk/Photographs/Barry%2009G.htm
Wortley Top Forge is also a museum.
- 8
honestrosewater said:Ah, Top Forge!? It's from the other side, but this must be it: http://www.topforge.co.uk/Photographs/Barry%2009G.htm
Excellent! How did you get it?
I was just looking for someone to say it was powering a tilt hammer in a forge, but you actually got the right place too! I was going to give you points for guessing Abbeydale (because it's very similar), but you hit the jackpot!
It's the site of an old forge (not foundry, sorry zanazzi!), which ended up making axles for trains. Not steel, but wrought iron. There are three waterwheels at the forge, all recently restored. Two power tilt hammers (one of which employs a rudimentary 'spring' mechanism to increase its power), and the other powered bellows for experimental work to develop the puddling process.
honestrosewater
- 6
Eh, you ruled out a lot, and Sheffield was a big help. After I ruled out every other water-wheel-powered tilt hammer in Sheffield, the picture ended up being on the first page of a google image search for "water wheel".brewnog said:Excellent! How did you get it?
I don't know how I missed it the first time.Okay, so for all you manly men out there:
http://void01.xs.to/pics/05263/smallclue1.JPG
Hm, is this too easy?
honestrosewater
- 6
There with fantastic garlands did she come,
Of crow-flowers, nettles, daisies, and long purples...
honestrosewater
- 6
Is no one playing or does no one know?
"There is a willow grows aslant a brook,
That shows his hoar leaves in the glassy stream;
Of crow-flowers, nettles, daisies, and long purples,
That liberal shepherds give a grosser name,
But our cold maids do dead men’s fingers call them:
There, on the pendent boughs her coronet weeds
Clambering to hang, an envious sliver broke,
When down her weedy trophies and herself
Fell in the weeping brook. Her clothes spread wide,
And, mermaid-like, awhile they bore her up;
Which time she chanted snatches of old tunes,
As one incapable of her own distress,
Or like a creature native and indu’d
Unto that element; but long it could not be
Till that her garments, heavy with their drink,
Pull’d the poor wretch from her melodious lay
To muddy death."
To muddy death."
Evo
Staff Emeritus
- 24,114
- 3,277
JamesU
- 3
looks like a quilt
Mentor
- 23,906
- 11,368
Colorado...?
Evo
Staff Emeritus
- 24,114
- 3,277
no to both, but Russ is on the right track
JamesU
- 3
how is that colorado?!
Evo
Staff Emeritus
- 24,114
- 3,277
It's not Colorado.yomamma said:how is that colorado?!
Townsend
- 240
- 0
Evo said:What is this?
Duh...
It's a picture...
Kidding...looks like the rockys.
JamesU
- 3
how is it simaler to colorado? is it a mountain?
- songoku
- · Replies 30 ·
- Introductory Physics Homework Help
- Replies
- 30
- Ozen
- · Replies 19 ·
- Aerospace Engineering
- Replies
- 19
- Amazed
- · Replies 11 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 11
- user079622
- · Replies 18 ·
- Mechanics
- Replies
- 18
- Zenon
- · Replies 7 ·
- Replies
- 7
- DanteKennedy
- · Replies 68 ·
- Quantum Interpretations and Foundations
- Replies
- 68
- quantum philosopher
- · Replies 31 ·
- Mechanics
- Replies
- 31
- Warp
- · Replies 7 ·
- Mechanics
- Replies
- 7
High School
What is x' for Moving Rocket from P?
- Lotto
- · Replies 2 ·
- Special and General Relativity
- Replies
- 2
- Suekdccia
- · Replies 1 ·
- Beyond the Standard Models
- Replies
- 1
