What is this paste on the wires?
  • Thread starter Thread starter kolleamm
    Wires
The discussion revolves around identifying a hard white paste found on wires in a servo. Participants explore potential materials used to prevent the wires from moving and touching each other, considering various applications and properties of these materials.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests the paste might be putty, speculating on its purpose to keep the wires from moving.
  • Another participant proposes that the paste looks like RTV (Room Temperature Vulcanizing silicone), expressing concern about the exposure of metal on the wires.
  • A different viewpoint considers the possibility of hot-melt glue being used, noting its suitability for assembly lines and low voltage applications.
  • Some participants reiterate the RTV hypothesis, linking its color and texture to that found on old CRTs, and questioning if it is the same material.
  • One participant provides an example of using electronics grade RTV to stabilize a radio antenna cable, suggesting a practical application of the material.
Participants express multiple competing views regarding the identity of the paste, with no consensus reached on a single material being definitively identified.
There are unresolved assumptions regarding the specific properties and applications of the materials discussed, as well as the implications of using different types of adhesives in this context.
kolleamm
TL;DR
paste name on the wires
This is a servo, there is some sort of a hard white paste keep the 3 wires from moving around and accidentally touching each other. It appears to melt with heat. Does anyone know what it is? My guess is putty.
Thanks in advance
Looks like RTV. Hopefully they used electronics grade, since it looks like some metal on the wires is exposed.
It might also be hot-melt glue. That is a nice quick solution for an assembly line. For low voltage, they could use just about anything.
+1
I have seen hot melt glue used in similar applications.
Color and texture looks like that on the old CRT's.
Same stuff? ie RTV.
Same stuff? ie RTV.
Looks like it to me. Here is an application where we use electronics grade RTV to stabilize a 2.4GHz radio antenna cable in a product (opened up for inspection)...
  • · Replies 31 ·
