What potential difference actually means
The discussion clarifies that potential difference, measured in Joules per Coulomb, indicates the energy required to move a unit charge between two points, but does not itself cause current flow. It emphasizes that while a charged capacitor exhibits a potential difference, it does not lead to current unless a complete circuit is established. The conversation also highlights the importance of understanding the role of resistors and the configuration of wires in electric circuits, particularly in applications like toasters where resistance is deliberately increased to ensure energy transfer efficiency.
  • Understanding of electric circuits and components
  • Familiarity with the concept of electric potential and potential difference
  • Knowledge of current flow and charge movement
  • Basic principles of resistance and energy transfer in electrical systems
  • Study the relationship between potential difference and current flow in circuits
  • Explore the role of capacitors in storing and releasing energy
  • Learn about the impact of resistance on energy dissipation in electrical components
  • Investigate the Water Flow Model and its limitations in explaining electrical concepts
Students of electrical engineering, educators teaching circuit theory, and anyone seeking to deepen their understanding of electric potential and current flow dynamics.
franjo
Does potential difference only indicate how much energy each coulomb have, or make current flow, or do both?
A potential difference is a measure for the amount of energy it takes (or yields) to move a unit charge from the one place to the other.
A potential difference (actually, the derivative of a potential) is a measure for the force a unit test charge experiences.
Current is (net) motion of charge.
Electric Field
Potential difference, by itself, does not make current flow. Consider a charged capacitor, there is a potential difference but no current.
I never understand why "Joules per Coulomb is Potential Difference" gives people so much difficulty.
Perhaps it's something to do with the fact that people look at an electric circuit and they seem more concerned with how the charges flow through the wires in a simple, ideal circuit than what goes on in the resistor or the battery. Wires, in practice, are chosen to be fat enough and short enough that very few Joules are dissipated for every Coulomb that passes through them. (That ensures that nearly all the Energy gets from the source to the load.) In an electric toaster, the element wires are specially chosen to have a much higher resistance than the supply leads so the Potential Difference across the actual element is very nearly the whole supply Volts.
I could blame that danged Water Flow Model which doesn't help in the slightest to help the student in that respect.
  • · Replies 64 ·
  • · Replies 54 ·
