What rate does water flow through the pipes?
The discussion focuses on calculating the mass flow rate of water through a horizontal pipe system with varying diameters. Using Bernoulli's equation, the pressure difference between the larger pipe (7.50×104 Pa) and the smaller pipe (5.70×104 Pa) is analyzed to determine the flow rate. The user derived the velocity difference and attempted to find the mass flow rate using the formula m = Avρ, where A represents the cross-sectional area and ρ is the water density (1000 kg/m3). The final calculations suggest a mass flow rate of approximately 68644 m3/s, although the user expressed uncertainty regarding the accuracy of their units and calculations.
  • Understanding of Bernoulli's equation and its applications
  • Knowledge of fluid dynamics principles
  • Familiarity with calculating cross-sectional areas of pipes
  • Basic algebra and unit conversion skills
  • Review Bernoulli's equation and its derivations in fluid mechanics
  • Learn how to calculate mass flow rate using the continuity equation
  • Explore the concept of pressure drop in pipe systems
  • Investigate the effects of pipe diameter changes on flow rates
Students studying fluid dynamics, engineers working on hydraulic systems, and anyone involved in the design or analysis of piping systems.
brunettegurl
A horizontal pipe 10.9 cm in diameter has a smooth reduction to a pipe 4.50 cm in diameter. If the pressure of the water (density = 1000 kg/m3) in the larger pipe is 7.50×104 Pa and the pressure in the smaller pipe is 5.70×104 Pa, at what rate (as mass per unit time) does water flow through the pipes?
Bernoulli's equation. Po+1/2(rho)v^2+(rho)gh= pfinal +1/2(rho)vfinal^2+(rho)(g)(h final)
if i sub in the necessary parts we know that h will be the same so that becomes a constant. Po is 7.50×104 Pa and Pfinal is 5.70×104 Pa so if we simploify the above equation we get P1-P2 = ½\rhov22-½\rhov12.so i solved for \Deltav by \sqrt{\frac{P1-P2}{0.5*\rho}} i got an answer of 6 but am unsure of the units to put in the answer..if this is actually the right working..pls. help
The rate of flow of water can be written as
m = Avρ
m^2 = A^2*v^2*ρ^2
1/2*m^2/A^2*ρ = 1/2*ρ*v^2
Substitute this value in the equation to find m.
i'm a little confused what value am i substituting in the equation to find m??and if i use the equation 1/2*m^2/A^2*ρ = 1/2*ρ*v^2
(m2/A2)*(1000)= (1000)v2
would my A= sum of both pipes diameter ...and what would v equal?l
P1 - P2 =1/2*ρ*v2^2 - 1/2*ρ*v1^2 = 1/2*m^2/ρ*(1/A2^2 - 1/A1^2)
P1 - P2 = 1/2*m^2/ρ*(1/A2^2 - 1/A1^2)
delta p =18000
A1= 9.331x10^-3
A2= 1.5904 x10^-3
i sub it in and get a value of 137030.15 ..does that look right??
I am getting 68644 m^3/s
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 30 ·
