What to study to become a mechatronics engineer?
To become a mechatronics engineer, students typically pursue a multi-disciplinary engineering degree that encompasses electronics, mechanical engineering, programming, and systems. Many colleges offer a dedicated mechatronics major or a concentration within mechanical engineering. Students are encouraged to engage with hands-on projects using tools like Arduino and Raspberry Pi to build foundational skills. It is advisable to avoid majoring in computer science if the goal is to specialize in mechatronics.
  • Understanding of electronics and mechanical engineering principles
  • Familiarity with programming languages, particularly Python
  • Experience with microcontrollers such as Arduino and Raspberry Pi
  • Knowledge of systems integration in engineering
  • Explore Arduino projects to gain practical experience in hardware programming
  • Learn Raspberry Pi programming for software control of hardware components
  • Research mechatronics degree programs and their course offerings
  • Investigate the use of IOIO cards for integrating Android devices with hardware projects
This discussion is beneficial for high school students interested in pursuing a career in mechatronics engineering, educators guiding students in engineering pathways, and hobbyists looking to enhance their skills in electronics and programming.
_ZERO_
Next year I will finish my IGCSEs (High school), and I want to become a mechatronics engineer.
Is a mechatronic engineering a branch? Or will I start immediately in studying mechatronics at college?
sorry if i sound confusing
Welcome to PF!
Mechatronics is a multi-disciplinary engineering degree. You take courses in electronics, mecahincal engineering, programming and systems.
https://en.wikipedia.org/wiki/Mechatronics
There's a lot of good references in the wikipedia article that should keep you busy.
Some info on Mechatronic degrees:
http://educatingengineers.com/degrees/mechatronic-engineering
I imagine if you wanted to get a start on learning more about it, try playing with an Arduino or Raspberry-PI. The arduino has many DIY hardware projects available online. Arduinos are more heavily hardware oriented with programming gluing together the hardware components of your project. The Raspberry-PI is more software oriented where python programs are used to control a limited number of onboard ports and the devices connected to them.
One other option is to checkout the IOIO card which can use an Android device as the computer to control some hardware components attached to the IOIO card.
Both adafruit.com and sparkfun.com sell these cards.
For a more lightweight but pricier approach, there's the little bits electronics at littlebits.cc Little bits are snap together components for mostly hardware projects. They do have a component for cloud based control of a project where you can use a device connected to the internet to control your project.
As far as the major you will pick, some schools have a mechatronics major.
If they don't, they might have a mechantronics concentration (usually in the Mech-e department).
If they don't have that, you can choose either mechanical or electrical engineering and then take relevant courses in the other major as electives. There will be programming that you will need, but usually you can take those through the EE department.
I wouldn't recommend doing comp sci as a major if you want to be a mechatronics engineer.
Thank you guys!
