What was the minimum power required?
  • Thread starter Thread starter MIA6
    Minimum Power
The discussion centers on calculating the minimum power required for a truck weighing 30,000 Newtons to ascend a hill of 1,600 meters, reaching an elevation of 800 meters in 480 seconds. Participants clarify that the work done is not the sum of potential energy (PE) and kinetic energy (KE) but rather the change in these energies, with no change in KE since the truck moves at constant speed. The correct approach involves calculating only the change in PE, as the work done against gravity is what determines the power output. There is confusion regarding the inclusion of KE and the factor of two in the total work calculation, which should not apply since only the truck's work is relevant. Ultimately, the net work done is zero due to the balance of forces, reinforcing that only the truck's work is needed for the power calculation.
MIA6
A truck weighing 3.0*10^4 Newtons was driven up a hill that is 1.6*10^3 meters long to a level area that is 800 meters above the starting point. If the trip took 480 seconds, what was the minimum power required?
My problem here is to find out the total work. I know that the work done by vertical position and along the hill is the same, and then divided by the time, so to get power. But I tried to use W=PE+KE, but it didn't come out the same answer. I used: PE=mgh=3.0*10^4*800, KE=1/2mv^2=1/2*30000/9.81*1600/480. then i added them up and divided by 480. It just didn't come out right. I don't know why i can't use this method?
Conceptually, your problem is that W is not equal to KE+PE. It's equal to CHANGE in KE plus CHANGE in PE. If you take the truck driving up the hill at constant speed, there is no change in KE. And I don't get why there is no 9.81 in your numerical expression for PE, and I don't get at all how you came up with the numerical expression for KE.
Ignore KE, all you are looking for is change in PE in a given time = power.
ps. There is no 9.8 in the pe because he is given the weight of the truck not it's mass.
Good point. And that explains the 9.81 in the KE as well but not the failure to square the v. Aside from the fact KE shouldn't be there at all.
Is that the formula for KE is different from the formula for change in KE, right? Former one is that simply speed, and the later one you need to find the initial and final velocity?
The solution for the problem is PE/480=5.0*10^4? But i think my teacher said the answer was 1.0*10^5 because she found out the total work was 3.0*10^4*800*2. She said that the work on incline of the hill is the same as lifting the truck in the vertical direction. But why should times 2? We don't have to do work twice? We just need to choose one way to let the truck go up?
It is assumed that there is no change in speed as the truck goes uphill, that is, it is moving at constant velocity, so that there is no change in kinetic energy. In which case, the total work done by all forces acting on the truck is zero. So the book answer for power delivered by the truck appears correct. The work done by gravity is the negative of the work done by the truck. Your teacher probably added the two to get a total work of twice the work done by the truck, when instead she should of subtracted the two to get a result of zero total work. Bit in any case, the problem does not ask for total work, just the truck piece. BTW, The 'v' in the kinetic energy equation is not a velocity, is a speed. KE is a scalar quantity.
You mean the total work is 0?
Yes. Some would call it the net work. By 'total' work or 'net' work, we mean the work done by ALL the forces acting on the object. Since there is no change in the kinetic energy of the system, the net, or total, work, is zero. This follows from the work-energy theorem:W_{tot} = W_{net} = \Delta KE
Just don't confuse total work with the work done by the individual forces. Total work includes work done by gravity.
  • · Replies 32 ·
12K
