What would be the speed of the approaching particle?
When two particles, A and B, approach each other at equal speeds, A observes B moving uniformly at twice their individual speeds, consistent with Galilean relativity. However, if both particles are photons, they would each perceive the other traveling at the speed of light, adhering to Einstein's special relativity, which states that the speed of light remains constant across all reference frames. As particles approach light speed, time dilation occurs, meaning time appears to slow down for them, but photons themselves do not experience time. It is more meaningful to discuss massive particles nearing light speed rather than photons, as photons lack a valid reference frame. The key takeaway is that while massive particles can observe each other approaching light speed, photons do not experience time or relative motion in the same way.
anti quark
Suppose that 2 particles, A and B, which are far away, are traveling towards each other at a constant equal speed. From A's point of view, will b be having uniform or uniformly accelerated motion? Wouldn't that be same from B's point of view?
And what would happen if A and B are traveling at the speed of light? What would be the speed of the approaching particle then? (here, let's assume A and B are light itself)
Ok. So this was a random thought I had a few days ago..
Thanks in advance guys!
In the first case, A will observe B to be moving uniformly at twice the velocity of the individual particles; the same would be true for B observing A. This is just Galilean relativity.
In the second case, if A and B are photons, each would observe the other to be traveling at the speed of light, with no doubling of the velocity. This comes from Einstein's postulate of special relativity which says that the observed speed of light is the same in all reference frames. To allow for this, it is the observed passage of time that changes between reference frames.
Ok, so in the second case, the passage of time for particle A would be changed?
According to special relativity, the closer we are to light speed, the slower time passes. So for the photon, time is still. Am I right?
It is best to avoid describing what a photon experiences. The speed of light is not a valid reference frame. Photons do not experience the passage of time.
Yes. It is more meaingful to talk about what happens as we approach the limit.
As above.
The best way to express this thought experiment is to discuss massive particles (not photons) moving at near the speed of light. Each particle will observe the other as approaching at near the speed of light.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
