What's the relationship between electric power and heat?
The discussion revolves around the relationship between electric power and heat, particularly how power consumed by electrical components like resistors and coils translates into heat generation. Participants explore both theoretical and practical aspects of this relationship, including mathematical formulations and physical principles.
  • Some participants express confusion about the mathematical link between power and heat, despite understanding power as energy per unit time.
  • Others explain that electric power can be converted into various forms of energy, including heat, and provide examples of how this conversion occurs in different components.
  • Participants discuss the Joule effect and its relevance to heat generation in electrical components.
  • Some contributions highlight the importance of effective resistance in components and how it relates to power dissipation using formulas like P = I²R or V²/R.
  • Specific heat and heat capacity are introduced as useful concepts for determining temperature changes in objects based on energy dissipation.
  • One participant notes that not all power dissipated by a component results in heat, citing examples like motors that may transfer energy without generating heat.
  • Thermal conductivity and its effect on temperature rise in components is discussed, emphasizing the role of the environment in heat dissipation.
  • Concerns are raised about the simplifications in energy transfer models, noting that real-world scenarios involve complexities such as energy loss to surroundings.
Participants do not reach a consensus on the relationship between electric power and heat, with multiple competing views and uncertainties remaining regarding the mathematical and physical principles involved.
Limitations include assumptions about efficiency in energy conversion, the dependence on definitions of specific heat and heat capacity, and the complexities of energy loss to the environment that are not fully resolved in the discussion.
This discussion may be useful for students and enthusiasts in physics and engineering who are exploring the concepts of energy conversion, heat generation in electrical components, and the mathematical relationships involved.
Guidestone
Hey fellas! Nice to be here again [emoji5]️
Here is the thing, everybody at school keeps telling me that the more power consumed by an electrical component such as a resistor or even a coil the hotter it will get. However, even though I understand that power is energy per unit of time and heat is a form of energy, I just can't see the link between both concepts, at least mathematically. I can just understand it intuitively.
Any answer will be really appreciated!
Energy can be converted one form to another. Electric power is generated using mechanical power, wind, solar, hydro, nuclear, heat, and chemical energy. Electric can be converted to mechanical (a motor), light, heat (a stove), and so on. That is what makes it so darn useful.
you're referring to instantaneous power.
If you dissipate 50 watts in a component for 1 second, how much energy was dissipated?
Power converted to heat in a component is always dissipated in an effective resistance in the component, so you can use P = I2R or V2/R to determine the power in watts from the current I through the resistance or the voltage V across it.
A resistor is mostly resistance (duh), but real inductors and capacitors have tiny effective resistances in series with their (non-dissipative) inductance or capacitance. Current through those effective resistances leads to power dissipation in those "non-dissipative" components.
Is that the mathematical link you were looking for?
50 Joules I guess. But how's that going to tell me how hot it is? There's something I read a few months ago about the Joule effect. Does it have anything to do in here?
I know those equations. They just don't tell me much about heat.
Thank you for the reply :)
look up what a calorie is.
lets assume the the resistive element i discussed is touching exactly 1 gram of water evenly.
how much heat generated in the water.
I think "specific heat" might be more useful -- it's a measure of the amount of energy required to raise a substance a certain number of degrees. With power & time (energy) and specific heat you can determine how hot your object will get dissipating that power.
For example, your real-world inductor is made of a substance with an average specific heat. If you know the current through it and its equivalent resistance you can calculate the power dissipated, and with that + time + specific heat you can determine how hot it will get.
Are we getting closer to the mathematical link you seek?
Heat Capacity is also a useful quantity. That looks at a specific object and asks how many Joules are needed to raise its temperature by 1°C. It's just the Specific Heat Capacity times the mass for a lump of a single subsatnce but, for an object with a mix of materials in it, it can be a useful parameter to use.
Only if a component dissipates its power as heat, will it will get hotter. If it dissipated it all as light, it would not get hotter. (of course, a real device would not be 100% efficient producing light and some power would be lost as heat, but let's ignore that)
If you had a 100% efficient motor driving a load, then it would consume power and transfer it all to the load. It would not get hotter. The nature of the load would determine whether the load got hotter. (maybe it is lifting a load)
Regarding the conversion of power to temperature:
Electronic components have thermal conductivity to the surrounding environment. It can be expressed in degrees/watt. So if a component dissipates 1 watt as heat and its thermal conductivity to free air is 100C/watt, then it will rise in temperature to 100C. If you connected a heat sink and the conductivity becane 25C/watt, then it would only rise 25C. Forced air could lower it even more, and so on.
Oh boy. And that is another can of worms. The basics of 'energy in = X times temperature rise' are never going to apply in reality. There are other forms of internal energy and there is always energy loss to the surroundings.
  • · Replies 24 ·
  • · Replies 51 ·
  • · Replies 16 ·
