What's wrong with this function
  • Thread starter Thread starter MHD93
    Function
The discussion revolves around the function f(x) intended to calculate the square root of 2, defined as f(x) = 2 + 1 / f(x/2) for x not equal to 0, and f(0) = 1. Participants highlight that the function is not well-defined for non-zero values, leading to contradictions when trying to compute f(0) and f(1). An alternative function g(x) is proposed, which is defined recursively, but concerns about its continuity and definition remain. The conversation emphasizes the importance of numerical analysis and the limitations of floating-point arithmetic in this context. Ultimately, while the iterative method shows promise, it requires careful consideration of its mathematical foundations.
MHD93
Hello
What follows is one way of calculating the square root of 2, as Wikipedia shows:
I built the following function as an attempt to express the calculation:
f(x) = 2 + 1 / f(x/2) if x is not 0
f(x) = 1 if x is 0
then square root of 2 = 1 + 1 / f(1)
I used the preceding approach to find the square root of 2, using C++, and it worked..
But the problem is that I have a way for showing that it's wrong!
What's wrong with that function, how can I convince myself logically!?
Thanks for help.. in advance.
Mathematics news on Phys.org
Something is missing. What is f(x)?
well, if f(0) = 1. The function relies on floating point rounding to calculate the other values of f(x).
Just curious ... I don't know anything about numerical analysis. To analyze a function like this, do we need to be told the value of N such that 1/N = 0?
f(x) = 1 if x is 0
This is uncorrect because :
you write (for x=0) f(0) = 1
and f(0) = 2 + 1/f(0)
since f(0)=1 your assuption is 1 = 2 + 1 = 3
He says "f(x) = 2 + 1 / f(x/2) if x is not 0".
But I still don't see a definition of f(x) when x is not 0.
Yes, you are right.
f(x) = 1 if x is 0
In fact, it isn't the right way.
Let define a function so that g(x)=1/(2+g(x)) any x
So that the infinite fraction is y = 1 + g(x)
What is the function g(x) ?
g(x)=1/(2+g(x))
g(x) (2+g(x)) = 1
(g(x))² + 2g(x) -1 = 0
Solving leads to
g(x) = -1 +(+or-)sqt(1+1)
The positive root is :
g(x) = -1+sqrt(2)
So, the function g(x) is constant.
y = 1 + g(x) = 1 +(-1+sqrt(2))
y = sqrt(2)
The value of the infinite fraction is sqrt(2)
Thanks for replies..
Many said "what is f(x)".. "it's not defined when x isn't 0"..
Actually, I see that it's defined.. here's a similar one:
g(x) = g(x/2) if x isn't zero
g(0) = 1
Let's try to find g(1)
Well.. by definition: g(1) = g(1/2) = g(1/4) = g(1/8) ...
In the end.. and after infinitely many steps.. doesn't the number between parentheses have to be 0, and then g(1) = g(0) = 1
That's the method I'm thinking about.. is it right?
g(0) = 1
I think that is pretty clever. You used your BRAIN to come up with a logical definition for f(0).:smile:
g(0) = 1
No, it's not right. Your function is not well-defined for any nonzero value. That's why the only way it makes sense is in the context of numerical analysis, when on some particular hardware, 1/N = 0 for sufficiently large N.
If your domain is the real numbers and you are using ordinary real number arithmetic, then how are you going to compute f(1)? You would have to do infinitely many operations and take a limit. That's not a valid definition of a function.
In a real world, physical computer, at some point 1/N is zero. That's numerical analysis ... when you take into account the physical representation of numbers in a computer.
That method requires that g is continuous. An extra assumption.
If your method reproduces the continued fraction expansion of sqrt(2) then i don't see anything wrong with using it.
I used your iterative function to reproduce the continued fraction expansion of sqrt(2) by hand, on paper.
If you are going to focus on technicalities why it shouldn't work then you are in danger of disregarding the fact that it DOES work.
It's sort of like grounding a plane because one of the passenger seats is missing...:smile:
