Gordon Watson
- Messages
- 375
- Reaction score
- 0
JesseM said:Since I don't understand the meaning of your "reference orientation" I don't understand what type of "conditioning space" you are using, as in your response to vanesch you say "The RO was given as c" and then condition all your probabilities on c. Normally a probability like Pab(++) would be conditioned on the fact that Alice chose angle "a", Bob chose angle "b", while the specific values of "a", "b" and "c" would be assumed as part of the conditions of the experiment. Indeed that seems to be what you do in Table 2 of the pdf when you write conditional probabilities like P(ab++|ab), but elsewhere in the pdf (and in your response to vanesch) you condition on other things besides the choice of two detector settings on a given trial, I don't understand the reason for that.
A reference orientation is any pre-agreed orientation of a detector in a Bell-test experiment, the experimenters (Alice and Bob) having here pre-agreed to three such orientations. (Thank you.)
The conditioning space in P(X|C) is C; as usual. And, as usual, the boundary conditions on the experiment are implied. So, as I believe is customary, only special conditions are included specifically. Since P(ab++|ab) differs from P(ab++|c), the model includes both. P(ab++|ab) is the probability of ab++ when correlated across the angle ab. P(ab++|c) arises from the use of frames of reference in the model, as in my reply to vanesch. I'll address this when I revise; in that I will be removing the Bell-test objection that you raise with regard to multiple tests.
I honestly expected no resistance to ADDITIONAL tests, over all 3 reference orientations. And thought it (for present purposes), better, less novel, than introducing the local-realistic basis for L*R. Will fix.
JesseM said:Where are equations (A0a) - (A0c)? If they're in the PDF, what page?
PDF2, Page 7.
JesseM said:No, I already showed the math for getting Table 2 from the probabilities in Table 1 doesn't work in [post=3159151]post 71[/post] which I hope you will review and respond to. If P(ab++|ab)=P3+P4, then according to Table 1 this will be:
[Sab.Cac + Sab.Sbc + Cac.Sbc]/6 + [Sab.Sac + Sab.Cbc + Sac.Cbc]/6 =
[Sab*(Cac + Sac) + Sab*(Sbc + Cbc) + Cac.Sbc + Sac.Cbc]/6 =
[2Sab + Cac.Sbc + Sac.Cbc]/6
And as I showed in post #71, for the angles a=240,b=120,c=0, this would be equal to 0.3125. But Table 2 claims that P(ab++|ab)=Sab/2, and for these angles Sab/2=0.375. So, the equations in Table 1 are inconsistent with Table 2, assuming you accept equations such as P(ab++|ab)=P3+P4.
PDF2 was written to correct the hurried mess that was the first PDF, with its short-cuts; including short-cutting the conditioning space on any P; noting that all P are conditional to me, in that some conditions are inevitably implied or explicit. So, with apologies, PDF2 now spells out every calculation. Which will bring you to those darned angles.
JesseM said:Your question makes no sense to me. The BT deal with a specific type of experiment, how would could the "allowance of additional tests" involving a totally different type of experiment be a way of breaching a theorem which doesn't address the second type of experiment at all? This is kind of like asking whether the "allowance" of an experiment on the breeding habits of Bengal tigers would "be the way that L*R breaches BT".
I thought that, when the L*R tests are conducted over every Bell-test detector setting (as they are; see Tables A1-A3), all we would have (and agree upon) is a more complete set of Bell-tests. I did not expect an objection to MORE tests; any component of which is a component of a Bell-test.
As for tigers: I thought that I was breeding Bell-tests.
So, for me, the question remains: Given that Table 2, PDF2, will remain unchanged, and since it applies to any Bell-test that you might nominate, how will a Bell Inequality be constructed?
To take a common example: How will P(ab++|ab) be yoked to P(ac++|ac) and P(bc++|bc)? The model being as one with QM in this respect?
It seems to me that these considerations will eventually move us to enquire: Is the model truly local and realistic?
That is: Local and realistic in line with Einstein's ideas and expectations? Me believing that he was not happy with the EPR elements of reality (too naive, imho), me understanding that he makes no mention of them in his work?
