Wheel physics -- which scooter would be easiest to get to school and back?
The discussion revolves around the physics of scooter design, specifically comparing lightweight scooters with smaller wheels to heavier scooters with larger wheels. Participants explore the implications of wheel size and weight on performance, including factors like rolling resistance, thrust, and suitability for different terrains. The context includes considerations for commuting to school, addressing both theoretical and practical aspects of scooter choice.
  • Experimental/applied
  • Some participants suggest that larger tires may reduce rolling resistance on rough surfaces but add weight, complicating the overall performance.
  • Others argue that lighter scooters with smaller tires may be easier to maneuver and require less thrust to get moving.
  • There is a discussion about the impact of terrain, with some noting that smooth surfaces benefit from harder, smaller tires, while rough terrain may require larger, softer tires for better traction.
  • One participant raises the question of how the weight of larger tires affects speed and ease of use, particularly in relation to the scooter's moment of inertia.
  • Concerns are expressed about losing traction with different tire types, particularly in turns, and how this might vary between scooter models.
  • Participants discuss the importance of practical testing, suggesting that trying out different scooters could help determine the best choice for the specific route to school.
  • Some participants highlight the design features of specific scooter models, such as the Razor A6, which is noted for being suitable for taller riders.
  • There is a mention of the trade-offs between weight and performance, with some suggesting that heavier scooters may coast further but require more energy to start moving.
Participants do not reach a consensus on which scooter is definitively better, as multiple competing views remain regarding the advantages and disadvantages of different wheel sizes and weights. The discussion reflects a variety of opinions on how these factors influence performance in different conditions.
Participants express uncertainty about the effects of tire size and weight on performance, particularly in relation to different types of terrain and riding conditions. There are unresolved questions about the specific characteristics of the scooters being compared and how they might perform in real-world scenarios.
This discussion may be useful for individuals considering different scooter options for commuting, particularly those interested in the physics of motion, rolling resistance, and the practical implications of scooter design on everyday use.
Greggl4321
I've got a physics question. I've been looking at scooters, one of them is light weight with a 98mm wheel, and several others are heavier with bigger wheels. I'm having a hard time phrasing my question, but what I'm wanting to know is what benefits are there too the bigger tired scooters?
They can roll over rocks better, so less friction/drag (not sure if these terms are used interchangeably)
But they are heavier, therefore, its going to take my thrust to get the scooter going.
How can I determine which scooter would be easiest to get to school and back?
Bigger tire seems to be less friction
and also less thrust
Would it be better to have a lighter scooter that I could get more thrust out of, or a heavier scooter that has less drag/friction?How do I even bigger to compare and contrast?
At a certain point, bigger tires add weight and make a short trip long.
Question is what is the best scooter?
Light weight with a small tire, or heavier with a bigger tire? ;)
My intuition is telling me the lighter scooter with the smaller tire is better than the bigger wheeled heavier scooter.
I'm thinking that the light weight scooter trumps the less friction/drag scooter.
Whatever energy is lost through friction/drag is easily recompensed by additional kicking. (Lighter scooter)
Welcome to the PF.
Is your route to school flat or does it have some hills in it? Is it all on asphalt or concrete, or is there some dirt/grass involved?
Bigger tires = less rolling resistance,
This doesn't necessarily mean bigger tires equate to less resistance, or na easier journey for lack of better terms, because they add weight.
At what point does the weight from the bigger tire start to slow you down
Only on rough ground. For dirt and uneven surfaces, you want a little larger (and fatter) tire with some compliance. For smooth pavement, you can go with smaller/lighter tires that are very hard -- that's how you lower rolling resistance.
I believe the problem remains conflated.
On my way to school I encounter hills, asphalt of varying poor condition, and sidewalk.
Why do you want some compliance for ruffed ground? (Im thinking okd asphalt that hasnt been repaved in a while that always has industrial trucks running down it with cracks in it ect)
There is a pneumatic wheeled scooter vs hard urethane, yet its been in my mind that these tires would be slower and have more resistance.
Where does it say bigger tires reduce rolling resistance only for smooth surfaces?
I think the problem is still unsolved, can additional people please chime in? Thanks for the response.
For smooth surfaces, hard tires minimize rolling resistance (picture Rollerblade wheels).
For surfaces with sketchy traction, larger and wider and softer tires improve traction at the expense of higher rolling resistance (think motocross tires).
For rolling over obstacles, larger wheels work better (at the expense of higher moment of inertia and weight).
Do your friends have any scooters you can borrow for a day each to try them out on your trip to school? You may be able to fine-tune your choice with just some practical experimenting on the actual route.
Still cinfused, this is what I've been trying to get at
Is the bigger tire and its lower rolling resistance going to slow me down because of the added weight?
Bigger/wider tires do have more weight and a higher moment of inertia (so harder to get rolling or change speeds). That's why road bicycles use skinny 100psi+ tires, and mountain bikes use wider tires at around 35psi.
You should probably only use tires/wheels that are big enough around to get over the cracks and bumps without too much discomfort, and use the hardest tires you can without making them dangerous when traction goes down briefly (like hitting dirt patches on the street or sidewalk).
Can you post pictures of some of the scooters and tires you are considering?
I'm unable to upload photos at the moment,
The scooters are the A6, and A4 from razor.
I currently own the A6, have owned the A5, and am now curious about the A4.
Another question is they say the A6 was designed for "taller riders", can someone explain what was designed on the scooter for taller riders?
Razor A4:
https://images-na.ssl-images-amazon.com/images/I/51oFjv1DcpL._SY450_.jpg
Razor A5
https://i5.walmartimages.com/asr/26....jpeg?odnHeight=450&odnWidth=450&odnBg=FFFFFF
Razor A6:
https://images-na.ssl-images-amazon.com/images/I/41+spWIHPbL.jpg
Yikes, I am filling a bit foolish. I can not recall why I got the bigger one, I liked the previous model a lot but wasn't thinking about the weight.
Yikes
So the smaller scooter will slow down quicker without kicking and will be more dangerous? I'm 6ft, 220lbs, what's the best scooter?
Someone mentioned that the bigger scooter would be better for distances, not sure why that is.
Larger wheels adds more stability, and longer handlebars for more comfortable posture... I'm 6'1" and riding shorter, smaller wheeled scooters gets uncomfortable really quick.
More weight takes more energy to get it moving but it also coasts further per push...
The weights of the A4 and A6 are 3.4 kg and 5.0 kg. When you compare it to your own weight however, that difference isn't significant. The difference in wheel weight is even less significant. For riding experience I would pretty much always take the A6. I think the smaller wheels of the A4 would be very uncomfortable on sidewalks or bicycle paths with tiles, or streets with bricks which are common in the Netherlands. The only reason to choose the A4 would be the price or if you have to fold it up and take it with you inside.
I fell today. I've noticed at times I lose traction. I don't think it was like this on the A5, why would that be?
I'm particularly losing traction around turns, why would this be?
Tires are too hard to maintain grip and lack of suspension makes bumps particularly dangerous.
Are the tires of the a6 harder than the a5 ? Cause the a5 didn't slide
No, I had the a5 lux, it didn't seem to lose traction like the a6 does.Not quite sure that this was answered, but which scooter is easiest to push back n forth from school? It'd be the a4 right? Since its the lightest? Can someone elaborate as to which scooter they think would be best?
For overall efficiency the lightest is best if you're zig-zagging low speed with little straightaways, and something with meat and a motor and batteries and torque on your traction wheel guided by your air filled, low rolling resistance, recharge braking/ inertial absorption system would be optimal for every advantage.
Even on straightaways it would be more efficient too though right?
was thinking this was the case, wasn't sure if I came to the realization on my own or through the article. I've (I think) decided to just push the bigger one, might get stronger. (or maybe I'd get stronger pushing lighter weight more often?)
Also, I'm wondering this.
Is losing a few pounds the same as the scooter being a few pounds less? (I'm not thinking so)
Is the weight on each wheel balanced?What'd cause the A6, with bigger wheels, to lose traction -- unlike the A5 lux.
I notice that the diagonal piece is much longer on the A6, not sure what that'd affect. Also, the axels are much higher, not sure if that gives a higher center of gravity, or puts more torque on the wheel when going diagonally.
Hope razor isn't out to get me now
Would they be?
I had some more written but I lost it.
I feel foolish for not getting the A4,
I just
Thank you all
Which scooter out of all of razors scooters do you think would be best ? The a4? Or something earlier
Would the 143 recommended weight limit be too little for 200lbs to 220 lbs? Or would I be OK?
The person who reviewed the a5 said a kick would push him further on the a5 then on the scooter with the 100/110mm wheel (razor A4)
How could this be? I thought people are saying the contrary is true?
Go for the biggest wheel possible.
It gives a smoother ride and the scooter will not stop or skid when it hits a pebble and throw you off.
Differences in friction and drag are so small in context as to be irrelevant.
32K
