When 0.123....495051/0.515049....321
  • Context: MHB
  • Thread starter Thread starter anemone
The discussion focuses on calculating the first three decimal figures of the fraction $$\frac{0.12345678910\cdots495051}{0.515049\cdots987654321}$$. Participants explored various approaches, including dividing smaller numbers and using significant figures in the denominator. The calculations stabilized around 0.2396, indicating that further approximations would not significantly alter the first three decimal places. Additionally, a calculus-based method was suggested to confirm the stability of the result.
  • Understanding of decimal fractions and their properties
  • Basic knowledge of calculus, specifically differentiation
  • Familiarity with numerical approximation techniques
  • Experience with significant figures in mathematical calculations
  • Study the concept of limits in calculus to understand stability in approximations
  • Learn about numerical methods for approximating functions
  • Explore the significance of significant figures in mathematical computations
  • Investigate further applications of calculus in error analysis
Mathematicians, students studying calculus, and anyone interested in numerical analysis and approximation techniques.
anemone
MHB
POTW Director
Hello MHB,
Recently I've come across a problem that jumped off the page at me (Find the first 3 figures after the decimal point in the decimal expression of the number $$\frac{0.12345678910\cdots495051}{0.515049\cdots987654321}$$).
I tried to approach it by making a table where I started to divide some smaller numbers but stick to the same pattern that is required by the aforementioned problem, i.e.
$$\frac{0.12}{0.21}=0.571...$$
$$\frac{0.123}{0.321}=0.383...$$
$$\frac{0.1234}{0.4321}=0.285...$$
$$\frac{0.12345}{0.54321}=0.227...$$
$$\frac{0.123456}{0.654321}=0.188...$$
$$\frac{0.1234567}{0.7654321}=0.161...$$
$$\frac{0.12345678}{0.87654321}=0.140...$$
$$\frac{0.123456789}{0.987654321}=0.124...$$
$$\frac{0.12345678910}{0.10987654321}=0.123...$$
$$\frac{0.1234567891011}{0.1110987654321}=0.111...$$
$$\frac{0.123456789101112}{0.121110987654321}=0.019...$$
$$\frac{0.12345678910111213}{0.13121110987654321}=0.940...$$
$$\frac{0.1234567891011121314}{0.1413121110987654321}=0.873...$$
$$\frac{0.123456789101112131415}{0.151413121110987654321}=0.815...$$
$$\frac{0.12345678910111213141516}{0.16151413121110987654321}=0.764...$$
$$\frac{0.1234567891011121314151617}{0.1716151413121110987654321}=0.719...$$
$$\frac{0.123456789101112131415161718}{0.181716151413121110987654321}=0.679...$$
$$\frac{0.12345678910111213141516171819}{0.19181716151413121110987654321}=0.643...$$
$$\frac{0.1234567891011121314151617181920}{0.2019181716151413121110987654321}=0.611...$$
and so on and so forth
but I failed to observe any pattern that's worth mentioning to help me to crack the problem.Could anyone help me with this particular problem? Thanks in advance.
Mathematics news on Phys.org
I also approached it by making a table, but I started by using the most significant figures in the given denominator:
$$\frac{0.1}{0.5} = 0.2$$,
$$\frac{0.12}{0.51} = 0.2352\ldots$$,
$$\frac{0.123}{0.515} = 0.2388\ldots$$,
$$\frac{0.1234}{0.5150} = 0.2396\ldots$$,
$$\frac{0.12345}{0.51504} = 0.2396\ldots$$,
$$\frac{0.123456}{0.515049} = 0.2396\ldots$$,
$$\frac{0.1234567}{0.5150494} = 0.2396\ldots$$,
$$\frac{0.12345678}{0.51504948} = 0.2396\ldots$$.
By this time, the fraction had stabilised (within the limits of my 8-digit calculator) to 0.2396987. I doubt whether further approximations would affect the first three digits after the decimal point.
Edit. You can confirm that by using a bit of calculus. If $f(x,y) = x/y$ then $\delta f \approx (1/y)\delta x - (x/y^2)\delta y$. With $x\approx 0.123$, $y\approx 0.515$ and $\delta x = \delta y = 10^{-n}$, you find that $\delta f < 2*10^{-n}$. So the change in the fraction after the eighth decimal places in numerator and denominator is never going to be sufficient to affect the first three decimal places in the quotient.
Hi Opalg,
I'm very thankful to you for showing me something that I had never thought about before and your solution and the proof work so beautifully...
Thank you so much!
